The controls are on the outside of the unit. There is no symbol as some have suggested using. I do not know how it became in the locked position. Any help is appreciated. Thanks much
It is not difficult at all! The answer is the user's instructions, and on this specialized site about dishwashers - https://washingcodes.com/bosch-dishwasher-error-codes/
You placed this in cars and trucks category.
SOURCE: door locks
Regarding the rear door child locks: There is a small lever on the latch side of the door, you can only see it with the door open. Move it to the other position.
Regarding the front door locks: You either have a bad door lock switch, or the power lock solenoids are beginning to fail. To check this, you will need to pull the door panels off, & measure the actual voltage at the solenoids whilst manipulating the lock switch. If you have 12 + VDC, I would suggest replacing the door lock solenoids. Not hard to change, but it IS time consuming. Best left to a dealer. Expect to pay 1 hour per side to change each solenoid.
SOURCE: Renailt megane 2000: Back door will not open
kind of hard but it can be done but what probly happen is that the child lock is hafe and hafe not ingaged or disangeged so it's stuck
SOURCE: outside door handler broken and child lock is on how do i open
Acura's and honda door handles are a little tricky to do.
make sure the window is all the way up.Then
1. u must remove the inside door panel.
next there is a plug on the inside edge of the door . remove this plug.
2. there is a 10mm bolt that hold the door handle on.
on some honda's and acura's door there will be a latch connecting rod. you will need a small tipped screw driver to remove this.
3. next there will be a 10mm bolt connecting the handle to the door inside. remove this bolt.
once the bolts carefully lift the handle upwards to remove the handle from the outside of the door.
At this point u can remove the door latch and other items that u wish to replace.
To install.. reverse this procedure.
Note.. is some cases there will be connecting wires to the handle and door latch itself. they must be disconnected prior to removeing and other components. Its a pain to do, but if u do not do this the connections could break and it is even harder to repair.
Take your time and don't force the parts apart. they are only plastic
SOURCE: 1998 Toyota 4runner driver side power door lock problem.
probably gonna have to take the door panel off. You say it wont unlock or lock with the key? if thats the case its probably broke inside the door.
