Question about Frigidaire Washing Machines
E41 error on my Frigidaire affinity washer
Keeps pausing after running a minute or 2
    Top Expert:
  • Frigidaire Master
  • 6,289 Answers
Frigidaire Affinity Washer Error Code E41 = Control board thinks the door switch is open. Usually replacing the door switch fixes and clears the error code.
Posted on Oct 28, 2018
SOURCE:
IFIXALL
  • 869 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
ngfam1
  • 639 Answers
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 25, 2008
Krazytech
  • 725 Answers
SOURCE: My washer is stuck in pause mode and when I
E41 Control board thinks the door switch is open. Remove the door lock assembly and measure the resistance of the PTC. Shortedor open.Defective door lock assembly. Around 1500 Ohms. Defective control board.
Posted on Sep 19, 2009
SOURCE: frigidaire affinity washing machine pause error
Because our machine was new and covered under warranty, we had a maintenance person come out three times for this issue, but the only solution he could provide was to use less soap. Apparently, too much soap disrupts a sensor. So, if you let the machine run without adding any more soap, it will (theoretically) fix the problem. And this solution did work, to a certain extent.
Even though I started using much less soap, the problem is still persisting. For awhile, I was successfully able to fix it by running a few cycles without soap. Now, however, it just won’t work. Maybe others will have more success with this solution than we did.
At this point, the washer is no longer cover under warranty and our best solution is to buy anything but a Frigidaire or related Electrolux product.
Posted on Aug 21, 2010
Jahn27
  • 1554 Answers
SOURCE: Frigidaire Affinity washer (LAFW3511KW0) with
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
Posted on Aug 21, 2011
What is code E41 on a Frigidaire Affinity ATF800FS. THE DOOR IS LOCK BUT THE DOOR LOCK INDICATOR WONT LIGHT UP & THE WASHER WONT SPIN
I appreciate your post, Trent!
Based off the information you have provided your Frigidaire washer is displaying an error code of E41 and the door is locked and will not open. An E41 error code means that your main control board thinks the door is open. I would recommend performing a reset on your washer and you can do that by disconnecting power from your washer for at least ten minutes. If that does not help correct your issue it could be a possible problem with your door lock assembly, control panel, or wiring harness. You may need to seek assistance from a professional technician to avoid unnecessary part purchases. I hope this is helpful to you. -Matt
Aug 03, 2015 | Frigidaire Washing Machines
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
Keeps pausing
Hello Friend, this is Z. Thank you for your post!
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 18, 2014 | Frigidaire Affinity ATF7000ES Front Load...
What is making my Frigidaire Affinity Washer FAFW3801LW fill and start working and then after 2 minutes there is an ugly noise and it displays "pause"?
Good Morning Doina,
I understand your Frigidaire Affinity washer, model# FAFW3801LW, will fill and start working. I also see that after about 2 minutes, you hear an ugly noise and your appliance displays "pause". I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FAFW3801LW Washer
Dryer is stuck on paused and won't spin. Turned off and re-started but the motor ran for a few seconds and then went to paused again.
Good Morning Jill,
So I see that you were drying bath mats and the dryer got stuck in a "Pause" mode and even if you cancel and restart it shows "Pause" on the display. I would suggest resetting the dryer. What you will need to do is either unplug it or you can shut the power off at the circuit breaker. When you do this you will need to leave it off for at least 2-3 minutes. Cut the power back on, start any cycle. If you are still having trouble not being able to start the dryer and "Pause" showing, I suggest you either contact the manufacturer or your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Mar 25, 2014 | Electrolux Dryers
My Frigidaire Affinity washer stopped working in middle of cycle and shows E41 code.
Hello Shawn Smith - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire upright washer E41
Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
E41
Control board thinks the door switch is open. You may need a new door switch.
Dec 23, 2012 | Frigidaire Affinity ATF7000E Front Load...
Error code e41
Hello phrainer3 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Oct 01, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
128 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
