The weather centre works perfectly except that I don't have an outdoors temp.reading since rain got into theoutdoor radio temp.sender
SOURCE: dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
SOURCE: atech weather station with
First thing to do is remove all batteries. After you do that, insert the new batteries into your receiver unit. After a few seconds, insert the batteries into first sensor (-> ch 1) After first sensor has connected (beep from receiver) insert the batteries into second sensor. Click on the link below to access the user manual for the WS303G
http://www.atech.hk/
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
SOURCE: auriol radio controlled weather station instruction manual Z29962E-RX
if the indtruction manual is not english then google the brand name and email your information model number etc.. ask them to email you a copy in english
