Watches Logo
Dhinesh Posted on Oct 27, 2018
In my skemi 1155 watch show only 10s how to solve it please tell me
How to remove watch band on skme1 1155 watch?
Go on Ebay and buy yourself a 'spring-bar tool'. It has a tiny forked tip (2-prongs) that fits around the end of the 'pin' that holds the spring-bar to the watch--push down and lever it out, and your watchband will come off. They're only a coupla bucks.
Jan 28, 2019 • The Watches
My Watch is showing military time but i want it to show in the 12 hr clock
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
http://www.fixya.com/support/t6812987-change_timex_wr30m_from_24_hour_12
How do change my timex wr30m from 24 hour to 12 hour display
Mar 21, 2018 • The Watches
I need Manual Instruction aboun watch Skmei 1155
There is a Skmei watch website that has instructions for all their models:
https://www.skmei-watch.com/index.php?route=information/information&information_id=33
there is also a Contact form.
Jan 01, 2018 • Watches
I need a watch manual for Skemi 1268
go to this link and i think its the second one down for the manual if its not just scroll down the page and see if you find one... watch manual for Skmei 1268 Google Search
Oct 24, 2017 • Watches
Skemi watch 1068 changing the time from 24 hour time to 12 hour time
On a different Skmei model, you can toggle the 12/24 settings within alarm settings. This also changes the setting for displayed time.
As I suspect that a lot of their models use the same internal module, it's worth a try.
Sep 29, 2017 • The Watches
5helpful
How do you set the time and date on a casio digital alarm chronograph 1155 WN-10 watch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
1helpful
Invicta model 3209 watch
Your watch is fitted with chronograph movement 5040D made by Ronda (Switzerland). If you take a closer look, then you will realise that the subdial at 3 o'clock is counting seconds allready. This is your seconds dial, not the big one.
The big seconds hand actually is the chronograph hand (stopwatch) and, when activated, works together with 1/10th counter.
Follow this link and see for yourself:
http://www.ronda.ch/e/index_bedienung.html
Find movement 5040D and click on INTERACTIVE version.
Rate me, please.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
