Washing Machines Logo
C
Cora Tolken Posted on Oct 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought Defy 6kg washing machine in August this year. Would like to know how do I get the filter out?
Mary Petrangelo
Level 2:
Welcome Back:
Visited the website for 2 consecutive days.
  • Expert 75 Answers
  • Posted on Oct 27, 2018
Mary Petrangelo
Expert
Level 2:
Welcome Back:
Answers
75
Questions
Helped
24353
Points
183
Do you still have the owners manual?? if so read through it. if not call where you bought it from or the manufacturer.
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Dec 21, 2008
SOURCE: how do I find and clear the filter in Hotpoint Aquarius wf210?
pull machine forward andtilt back look underneath machine at bottom ofplastic tub u will c a black pipe leading from the tub t the pump unscrew from the tub end (put a bowl down first as water will come out)pull off pipe inside u will c a white platic collecter pull that out clean and put back together hope this helps
Anonymous
  • 291 Answers
  • Posted on Apr 03, 2009
SOURCE: defy automaid instruction manual how to use
click the link below for defy automaid manuals and instructions guide:
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
thanks and plse do not forget to accept the solution.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on May 27, 2009
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
luisa_sgro
  • 713 Answers
  • Posted on Jun 19, 2010
SOURCE: simpson encore 605 wash machine 6kg. Washer pump
Hi mark just read your posting.Now what country do you live in.If you live in Australia then I can give you some phone numbers.Regarding your machine it does sound like the control board.Probably the power supply section of the board is faulting.Please reply with additional information and I can help you further.
Testimonial: "Nice reply with information to put me in contact with someone who may have parts. Thanks. I await some more contact phone numbers."
Anonymous
  • 15935 Answers
  • Posted on Sep 15, 2010
SOURCE: My washing machine Defy 1300 can't wash, u load
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
My Defy DAW381 6kg front loader washer wont start. I select a program and press start, but then the wash symbol keeps flashing without starting.
Check the pump for blockages. If the pump doesn't pass self-test, it stalls the program.
You can also try a power reset, remove the power plug for 30 minutes.
https://www.google.com/search?q=Defy+DAW381+won%27t+start
1helpful
Problem with hotpoint aquarius wml520p 6kg 1200 spin washing machine doesent go into final spin
Have you checked the filter if fitted? Sometimes washing machines will not spin if they're not empty.
My defy daw 365 front loader washing machine won't start. The "end" indicating light stays on and the "door" light does not come on.
hi we just bought a second hand defy front loader washing maching can you please assist us how to use ot its Defy Daw 365 please
2answers
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
12helpful
2answers
Defy automaid instruction manual how to use
Top Washing Machines Experts
john h
