SOURCE: Where is the thermal fuse for Kenmore 665 11073342 dishwasher?
The thermal fuse is located in the front control panel where the circuit board is. You need to remove 4 screws(depending on the type of dishwasher you have) and you will see it. Make sure you change everything not just the fuse but the new wires also.
Hope this fixes your problem
SOURCE: Manual/datasheet for siemens sitop 10A power supply
batteryconector pulled from the pannel, how can i solder it again
SOURCE: no power to dishwasher...cb ok...outlet
Hi Please post back with the manufacturers name and model no of
your Dishwasher for further assistance. Daniel
SOURCE: maytag dishwasher has no power
Hi Please post back with the manufacturers name and model no of your Dishwasher for further assistance. Daniel
SOURCE: Kenmore dishwasher. Model 665.13593K600. No
Hi If
the dishwasher is not working with no lights or display then the most likely cause is
an open thermal fuse.It is located in the console and can be checked for continuity with a
meter or it can be bypassed if no meter is available. The thermal fuse will
have a black wire and a black/white wire on it. If you have no meter then with
the power turned off you can remove these two wires and join them together with
a small piece of insulated wire and see if you get any lights. One other
possibility is the wire connections at the dishwasher junction box behind the
kick plate. Sometimes the wire nuts get loose and a good connection is lost. Often
the main wiring connection from the house, at the dishwasher, burns and breaks
the connection. If that's the problem, the wires must be repaired/replaced as
necessary. If that's not the problem, check the wiring to the door switch, the
wiring between the door and the lower part of the dishwasher, and the wiring to
the timer. Repair any broken, burned, brittle, or defective wiring, using the
proper appliance-grade wire and connectors. Please
get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
