Question about Casio Office Equipment & Supplies
Casio XJ-H1700 Temp light problem After turning on the projector, the power and temp light turn steady red and the projector will not turn on.
SOURCE:
  • 3422 Answers
SOURCE: Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Posted on Feb 25, 2008
cTech1
  • 66 Answers
SOURCE: hitachi projector temp light
This is what your projector's user manual says about a flashing "TEMP" light :
"The cooling fan is not operating. Turn the power OFF and wait approximately 20 minutes. After the main unit has cooled down, please make confirmation that no foreign matter has become caught in the fan, etc. After performing any needed maintenance, turn the power ON again; if the same display is displayed, then please contact a sales store or a service company."
Your user manual is available at the following link :
http://www.hitachi.us/Apps/hitachicom/content.jsp?page=Products/SupportServices/Support/DiscontinuedModels/index.html&level=4&section=Products&parent=DiscontinuedModels&nav=left&path=jsp/hitachi/forhome/DisplayTechnologiesGroup/
Posted on May 20, 2008
SOURCE: Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
Posted on Jun 12, 2008
projdoc
  • 2237 Answers
SOURCE: PROJECTOR PROBLEM
it wasn't able to go through the cooldown mode. turn it on and power down, letting it go through the cooldown mode. does the lamp come on at all?
Posted on Aug 19, 2009
projdoc
  • 2237 Answers
SOURCE: the projector doesn't turn on.power,temp,lamp orange light are on
overheated. clean it out with canned air. try again. if it still has an issue, you may have a main board problem.
Posted on Nov 12, 2009
Why does red TEMP light come on after power up?
The fan is important. If it doesn't turn at the correct speed the red light will come on. Replace the fan and that will fix the problem Go to Casio's website to get the part or try here:
Nov 21, 2015 | Casio XJ-251 WXGA DLP Projector XJ-A251
Projector problem HELP!? my projector was on whiles the utility power went out, and when the power came back i realised it had affected my projector, when i put it on (press the power button) the:...
Kindly get intouch with Cinesonic Audio Visual Pvt. Ltd. in New Delhi at 10/2, DLFIndustrial Area, Shivaji Marg, Moti Nagar,
New Delhi-110015
Contact: ' Board: +91-11-47424444 (30 Lines)'
e-mail: Robert@cavpl.com
For any problem related to Casio Projectors
Mar 21, 2011 | Casio XJ-S31 Projector
The projector turned itself off after couple hours of use and the Temp. red light came on. Power Light turned red instead of orange as usual. After 3hrs I turned it back on, cleaned the dust off the fan...
There are three temp sensor inside the projector and now your projector need full service but if the air filter becomes clogged with dust, the internal temperature of the projector will rise, the TEMP indicator will illuminate and the projector's power will turn off (the TEMP indicator will flash after the power is turned off) The air filter should be cleaned every 100 hours of use.
If you clean the filter with a vacuum cleaner to clean off any accumulated dust. then your projector working normally
Jan 03, 2011 | Panasonic PT-LB50U Multimedia Projector
Casio xj-s41 lamp and temp light amber blinking
FIRST LOCALIZE THE UP/ DOWN/ LEFT/ RIGHT AND MIDLE BUTON- ON FUNCTION CONTROL
OK...
KEEP PRESSD FOR 10 SEC
INPUT / MIDLE BUTTON FROM FUNCTIONS/ AND RIGHT ARROW
RELEASE THOSE BUTTONS
NOW YOU SHULD GET THE ERROR RESETED.
NOW YOU HAVE TO INITIALIZE THE UNIT:
POWER OFF UNIT( FROM POWER BUTTON)
POWER ON
PRESS AGAIN: INPUT/ MIDLE BUTON/ RIGHT AROW TILL SHOWS A SERVICE MENU ON SCREEN
CHOSE INITIALIZING AND RESEAT UNIT.
GOOD LUCK...GO CANUCKS
Nov 30, 2010 | Casio XJ-S41 SuperSlim DataProjector ...
All the lights are on: power light, lamp light and temp light... How can I fix it?
If you have the manual you can look at the back for troubleshooting. The problem or solution will depend on if the lights are blinking and what color they are. The manual can be found here. You will want the basic operations manual.
http://support.casio.com/manualfile.php?rgn=1&cid=007001005
I just had a XJ- S41 projector in for repair because it wouldn't power on. The power light was red solid but the temp and lamp lights were blinking red. Apparently a reset was needed, but I was told it was an internal reset that had to be done be a technician. I'm dubious of this info as I've seen some reset procedures listed on this site that may have worked, but I can't confirm as I sent it in. It cost $45 plus shipping to have Casio do this reset and there was nothing wrong with the projector or any parts replaced. Casio wouldn't tell me exactly what reset procedure was done and they will not let you speak with a technician or even try and get more info for you. Using their online repair service though was easy and swift. Just go to www.ecasiorepair.com.
Nov 12, 2010 | Casio XJ-S31 Projector
PROJECTOR PROBLEM Casio XJ 31
it wasn't able to go through cooldown mode. turn it on, power down and let it go through cooldown. does the light come on at all?
May 31, 2009 | Casio XJ-S31 Projector
Jan 22, 2009 | Casio XJ-S31 Projector
Problem with Casio xj-s35 projector
You have to disconnect power to reset it.
Nov 08, 2008 | Casio XJ-S35 DLP Projector
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
