SHARP MODEL:SJ-F76PS [PROBLEM FANMOTOR NOT WORKING] I BOUGHT NEW FAN MOTOR STILL NOT WORKING
SOURCE: i have a fac106p1 eng2, overheating fan motor
first check the capacitor measure, see if measurement correspond with its label ex. 40 mf or 50 mf. I believe the winding for the fan motor are loosing its insulation, you might need to replace the fan motor, if installing new one follow the diagram and rotation their is an arrow indicating the rotation of the fan blade
SOURCE: i have a ge sbs model pcp23shmffbs. the condenser
If the motor is running, but running slowly, you will need to replace the motor. If there was a problem with the PCB, (control board) the motor would not run at all and you would see other problems with the refrigerator.
Here is a link to the motor.
SOURCE: ge model pcp23shmffbs slow running condenser fan
I would change the PC board. Here is a link to the part.
SOURCE: how do change the
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
