SOURCE: RM2652 fridge works on 110 and gas but won't switch between them
Remove the upper control board panel. Use a small screw driver, open the freezer door, under the control panel you will see a slot on each side. Put the screw driver in the slot and push up. That side of the panel will pull out. Do the same on the other side. Turn the control panel over and unplug the circuit board and wait 15 seconds. Plug the board back in and give that a try. If that does not work replace the upper board. To order a board you will need Model, Serial and product # found on the inside of the fridge.
Thanks for using Fixya
Jerry
SOURCE: i need a service manual for Atwood 2001 series RV LP gas detect
Call one of the motor home supplier and you will be able to get it.
SOURCE: My Atwood LP Gas Detector is sounding an alarm every 30 secs.
The alarm you are getting is telling you that the battery has nearly gone. Some gas detectors you have to renew as the crystals used to detect the gas oxydise after about five years, and are no good.
May pay you for your safety to get a new one. Try Wallmart or similar.
SOURCE: triple rocker switch to control 3 function bathroom fan/light
I suggest you cut 3 pigtails out of your black wire (about 5-6" each and strip them so you can put a nut to tie them all together on the main wire, then do the same for your grounds using green 5-6" strips of wire and then connect all 3 switches with the pigtails to their proper locations. This WILL fix your problem.
SOURCE: The LP gas detector alarm is going off and I can't stop it.
Unfortunately, it may have to be replaced. Not uncommon for those to be affected by humidity, condensation etc, hair spray, aerosols, moth balls too close, etc. and begin to malfunction. Just be sure propane is off. They can be bench tested,(out of the unit) with a battery, just to be sure it's time to replace it.
The previous answer is correct, but there are often two fuses in the inverter to split the output. Maybe one is blown. Robert
