Question about Casio Music
We have the Casio Electronic Keyboard WK - 500. There was no Substain Peddle when arrived. So I need to find one.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
Https://www.amazon.com/casio-keyboard-sustain-pedal/s?page=4&rh=i%3Aaps%2Ck%3Acasio%20keyboard%20sustain%20pedal
Posted on Oct 31, 2018
5 Suggested Answers
SOURCE:
  • 411 Answers
SOURCE: SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Posted on Jun 19, 2009
  • 1126 Answers
SOURCE: How to save setting changes on Casio WK-500 keyboard?
This is a link to WK-500 owners manual.....SD Card information is on pages E-59 thru E-64...
http://support.casio.com/pdf/008/WK200_500_e.pdf
Posted on Oct 22, 2009
  • 5603 Answers
SOURCE: My WK- 3700 Casio keyboard is malfunctioning.
One portion of the key scanning matrix has gone bad. First thing is to clean the contacts with 99% isoprophyl alcohol. These USUALLY consist of traces on a circuit board that conductive rubber "pills" under silicone rubber domes are pressed down. Each note usually has two contacts, one closes before the other. This creates "velocity" measurement for the key. IF ONE of the contacts for a key doesn't work, the velocity can detect that the note has actuated, but no release occurs.
This would be on the "STROBE" line for either the first or second contact for THE OCTAVE you have problem with. There are disconnect diodes that prevent sneak paths.
You could have one bad diode, a crack in the circuit board, or a bad connection to the keyswitch board.
Posted on Nov 27, 2009
aquaman987
  • 927 Answers
SOURCE: I have a Casio electronic
ALBERTA
E NESA
121-3208-8 th Ave NE
CALGARY , Alberta T2A 7V8 403-252-6988 BRITISH COLUMBIA B E Cal-Q-Tronics
#225 - 624 6th Street
NEW WESTMINSTER , BC V3L 3C4 604-524-4926
Fax: 604-524-4928 MANITOBA B E (No diaries) NESA
1580 Erin Street
WINNIPEG , Manitoba R3C 2T1 204-783-6185 NEWFOUNDLAND E Bristol Business (West Empire Plaza)
391-395 Empire Ave - Unit 6
ST. JOHN 'S , Nfld. A1E 1W6 709-722-6669 ONTARIO A B C D E F Casio Service Centre
141 McPherson Street
MARKHAM, Ontario L3R 3L3 905-248-4400
800-661-2274 QUEBEC A B D C E Madjitech (Omar)
1202 Bossuet
MONTREAL , Quebec H1N 2R4 514-255-7299
Gary
Posted on Feb 23, 2011
Do u know if this keyboard has a protect voltage/amp fuse?
Most electronic keyboards will have a fuse. If it is not on the rear pannel, it will be inside on the power supply board.
Apr 18, 2016 | Casio Wk-200 Wk200 76-key Digital Personal...
Correct adapter for casio wk 500
Casio AD-12 for my country with 240V
You may use any 12V 1A AC Adaptor that has the same DC jack provided the center is NEGATIVE. Most common generic AC Adaptors are Centre POSITIVE.
So cut DC end of the wire and solder them in reverse and insulate with tape and it will work.
Jan 20, 2014 | Casio Lighted Keyboard LK90STADMC
It wont power up
Do You use original CASIO power adapter for this keyboard?
Some CASIO (CTK-5000) models require inverse voltage polarity than most of others adapters have!!! RISC OF BURNING OUT ELECTRONICS!!!
Dec 09, 2012 | Casio Wk500 Wk-500 Keyboard Workstation...
When I plug in stereo headphones in the casio wk 210, the sound only comes out of one ear. I didn't really care about that before, but now when I connect a line out from the piano to my computer to...
The output of the casio may only be mono, you can buy splitters to create a 2x channel output. Is there any other outputs from the casio other than headphones, usually there are red/white RCA outputs (Phono's) which would be better for connecting to your soundcard.
Hope I was of use to you, good luck.
Aug 04, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I want to record from my wk 500 to my imac
You have to get a cable that runs from the 1/4 inch headphone jack on your keyboard to the 1/8 inch line in on the back of your iMac.
Jul 01, 2011 | Casio Wk500 Wk-500 Keyboard Workstation...
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Oct 22, 2009 | Music
No.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Music Logo
54 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
