SOURCE: ps 52 kx power supply will not hold load
thank you for your help . I have already fixed the power supply I double checked the transisters and found three bad so I replaced all the power transisters and it is fine . thanks again bob
SOURCE: electrical problem in turn signals and brake lights
Sounds like a bad earth/ground - remove the lense covers and clean the bulb panel contacts also check the brake and indicator switches for rust on the contacts, Hope this helps
SOURCE: My dometic frig will not work no power. Has 12 volt and 110 volts
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
SOURCE: Which fuse controls the 12-volt outlets. I have
check the accessory fuse, might be labeled as a cigarette lighter or accessory.
SOURCE: My Heart inverter is not charging the batteries.
it might be that it is not receiving power to charge it or the charging fuse or power input fuse is broken
