The battery indicator will flash and/or the IC recorder will display the error ACCESS when the batteries are low. Install new, fully-charged batteries to resolve this issue. NOTE: Be sure to install the type of batteries specified in the user manual.
Hi if the radio is the coded type you will need to know the code to enter it back in when the new battery has been installed
Also when removing the battery connections always remove the negative first.
When installing the battery connect the negative last
I hope this is of some help to you
John (South Wales UK )
Hi, the maximum memory you can install is 1GB of RAM...
to install, remove the battery first, then unscrew the screws at the corners of the bottom part of laptop then remove harddrive then insert the memory. ..
Fuses, and make sure you got all of the wires hooked to the alternator, and that they aren't burn't. Some older vehicles had "fusible links" which is a wire that opens when the load is too great. It's like a fuse.
Have you tried removing the battery, open the reserve battery door, disconnecting cmos (RTC) battery, pressing power button, installing RTC battery, install battery, power up?
