My recommendation is to reset the LED light wire and battery pack. To do this, disconnect the LED light wire from the solenoid. Disconnect the battery pack and wait a full minute. While you are waiting a full minute, you can check batteries to see if they are in good condition, even try new batteries. Make sure all batteries are in the correct direction and are tightly secured in the battery pack. After a full minute, reconnect the LED light wire into the solenoid and then reconnect the battery pack. Wait another full minute. After the full minute, you can then check your faucet and see if the lights work . If this procedure does not fix your issue, contact Delta Customer Service at (800)345-3358 Monday-Friday, 7am-7pm, CST and Saturday, 8am-5pm, CST. You may also email them at [email protected].
SOURCE: 1999 oldsmobile delta battery changed but won't power on
If everything else checks out Ok in the ignition system (electrical) and if the engine and transmission turn freely,that sound like you might have starter drag.Check to see if you have good connections at the starter.I know its new but check your battery for 12 volts,good connections,ect.
SOURCE: can I replace delta faucet t2710 with Delta SBS 84010BN ?
yes . when buying the faucet dont forget to buy stainless steel suply lines for water line connection.
SOURCE: Faucet and shower head leaking
Is it a single handle faucet set? If so it sounds like you need to replace the stem in the faucet itself. You can get to this with a screw driver and a pair of pliers. Turn off the water to the faucet (hot and cold) and remove the handle. Once you do this you will see a clip that hols the stem in place.Remove this clip and pull the stem out with the pliers and you can find a replacement at your local Lowe's, Home Depot, etc. Pay attention to the directions when reinstalling. there is a tab that determines the top side of the stem.
SOURCE: DELTA SINGLE HANDLE GOURMET SPRAY faucet
Hello. Actually it is not difficult to remove the faucet. If you can pull up the sink with faucet attached it will be very easy. Otherwise get under the sink with a flashlight and you will see what tools are needed. A special extendable faucet wrench from Home Depot would come in very handy. Regards. Joe
