Video Cameras Logo
b
billy Posted on Oct 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do you still care about your clients from n1 city because i called in and spoke to a very rude attendant and i dont want that
Jean DeLauche
Level 3:
  • Video Cameras Master 2,911 Answers
  • Posted on Oct 25, 2018
Jean DeLauche
Level 3:
Answers
2911
Questions
Helped
974381
Points
13029
Hello, Billy -
I have no idea where N1 City is located. Nor do I have any idea what business you are complaining about.
In case you do not realize it, Fixya.com, where you posted your complaint, is a website intended for asking and answering questions on how to go about REPAIRING THINGS. It is not a consumer complaint website for any location or business ANYWHERE.
Fixya receives questions from people worldwide.
I suggest you find the telephone number for the N1 City business which concerns you, make a phone call, and speak with the manager to discuss your concerns.
I am answering from the USA.
Best wishes.
1 Related Answer
curlycord
  • 277 Answers
  • Posted on Nov 05, 2012
SOURCE: When clients call in and get our main number, they get our new auto attendant message. When their call is routed to the next available line, they get our OLD auto attendant message which has changed.
Log into voice mail with password and go to AA/Lines and tell each line to use the same Table #.
Rude Customer Service
Try Ice-o-Matic ... they are very similar to Scotsman machines
How many pc's, laptop's & printer's can i link up to belkin n1 vision wireless router model f5d8232-4
You can uplink a fairly good number of PCs or laptops with Belkin N1 as it supports high bandwidth. Keep in mind that upon adding every new PC, the overall bandwidth for the other PCs is reduced. If the PCs/ laptops do not require much bandwidth, you can connect / add more PCs to the network.
Generally, I have uplinked upto 10-15 clients to one router and the network worked just fine. It all depends upon the network environment and the bandwidth usage by each client PC. If the PCs are using just email and simple internet browsing (and remain idle for most of the time), you can add more clients to your network as not all the systems consume network resources at the same time.
Hope it helps! Good Luck!
CreativeTECH
Change Auto Attendant message to Rollover Calls to Ext. 10 and 15
**use with care ** if it is a "Partner System" here you go. if unsure do not do this. it is simple but one wrong keypress will cause ... mmm problems. so just hang up if unsure. dial intercom 777 , then * to get main greeting, if ok then * again then enter extesion should be prompted. press 0 # then password , default is 12345678 #. if it is good dial 9 (administration) then 3 (auto attendant) then 1 , 1, 6, * , # then 1 to record and follow prompts.
5helpful
Mitel IP5207
you will need access via the web browser to the 3300 esm (database). Assuming you have a user log on ... select all forms alphabetical and select multi-level auto attendant. This will list all auto attendant boxes. High light the required one and click change. You can now change the option 1,2.. dialables
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
