SOURCE: Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
SOURCE: Alpine CDA 9886 car stereo
I read the manual and found out that the reason the track title information does not display is because you need to set the text scroll setting to manual.
Go to settings
Display
Text Scroll
set this to manual.
Should be fixed!
SOURCE: 2009 Escape. When I purchased this year, I mostly
Does it do this on all radio stations? Some stations don't broadcast that information, some do. Also there may be an info button somewhere on the radio, try pushing that to see if it comes up.
SOURCE: I have a 2008 dodge ram slt and cant get
The information as to what is playing is part of the data stream sent by Sirius, and I've never seen a satellite receiver that does not display this information. If this is a factory unit, information on its operation should be in your owners manual (and your dealer is there to help you). If this is an aftermarket radio, you ought to have an owners manual which should describe how to change the information displayed on the faceplate. Either way, the unit should give you full information about the data stream it is receiving. If not, something is amiss and may fall under warranty coverage.
