Question about Navman GPS
My Navman will not charge using the USB stick - Navm85LM - I am asked to follow prompts, however I cannot bring these up on screen
4 Suggested Answers
SOURCE:
  • 7 Answers
SOURCE: Navman N40i
you have a small button on the side of your navman, an ON/OFF button! put it in the OFF state, leave it for a few minutes and then put it back ON and it should solve yourr problem
Posted on Feb 10, 2008
SOURCE: Battery Charging Navman S90i
The problem is that most of the chargers have the output of 5V/0.5A. The charger for NAVMAN (C30 in my case) has 5V/1A. And that is causing the trouble. The GPS is undercharged and is switching off itself. Buy one which specify the output power: 5V/1A. Hope I solved your problem
Posted on Feb 05, 2011
SOURCE: Can NavMan 520 charge via USB?
I received a navman as a present but it only has a card connection to charge but how can charge for 8 hours for the first use. happy to hear any suggestions!!!!!
Posted on Sep 01, 2011
I have connected my navman to my computer to install the updates. I am not sure if it is doing it as no prompts appeared on my screen. On the Navman I see a computer and the Navman and the connection. ...
Assuming you have NavDesk already installed on your computer, you have to open the NavDesk software/program. Once the software recognize the device, you will be prompted if an update is available. Then follow the prompt to update the map/application.
Mar 03, 2014 | GPS
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
Mio spirit navman 380 how do i set it up
it should have came with a disk
connect it to a computer using the usb lead connection
insert the disk and follow the installion prompts
Dec 01, 2011 | Navman GPS
How do I format a Kingston 8-GB Data Traveler 101 flash drive which is write-protected?
You can try to go to safemode (to go to safemode restart the computer then tap F8 while restarting then select Safe Mode with Command Prompt) Note: you have to have the flash drive connected before restarting After loading files if your USB Memory Stick drive letter is (F) for example then write as C:\windows\system32>F: and press enter F:\>format F: and press enter If it ask you (Y/N) then press (Y) and press enter It should reformat the usb flash drive
You can also check out the registry under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
The value should be "0".
Jul 09, 2011 | Computers & Internet
Screen is frozen, can be turned on and off but wont go passed initial stage
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
May 17, 2010 | CaseCrown Navman S50 Portable GPS...
Hi I am using Navman S30 car navigator. It has been giving me problems now. Every time I connect its charger, it turns on and gets stuck on the usb connection screen. I have changed its charger but I am...
Open your usb cable with a sharp knife; you'll find four different coloured cables inside: leave the red and black cable intact; cut the other two. Close your cable with some tape.
Your navman won't go into usb mode again, but it will charge your device
Dec 23, 2009 | Navman S30 Car GPS Receiver
Navman f20 will charge fron usb port on computer but not with in car charger
If it's not the original Navman usb loader then there's a easy solution to this : With a sharp knife carefully open the usb cable : you'll see four tiny cable's with different colours . You;ll have to cut two of those four cables ; Leave the black and red cable intact.
Use some tape to fix the cut in the usb cable. Now you can use your car charger and your navman won't go into usb mode.
Dec 08, 2009 | Navman F20 GPS Receiver
Feb 04, 2008 | Navman F20 GPS Receiver
Navman S80 will not let me go passed the safety agreement
When I turn my unit on all I can see is the accept/decline screen. The unit will not load the maps. How can I fix this?
Step 1
Connect your Navman Device to your computer via a USB cable.
Turn on your device and you will see a connection screen appear.
Step 2
Wait a few Seconds until a window appears on your desktop and then select “open folder to view” by double clicking on it
Step 3
Once you have opened this folder you will need to double click on “My Documents”
Step 4
Once my documents is opened locate and files that starts with “LOG00” and also “My Mileage” and delete them
Step 5
Once the above steps are done you may disconnected your unit from the computer.
Turn your unit on and enter your main menu page 2/2 and select “Preferences” then select “Route Options”
Once this is selected go to page 4/4 and un-tick “Enable GPS data logging” and “Enable trip recording”
Your unit is ready to use and will run a lot smoother due to increasing unwanted data and freeing space to increase optimum performance. We suggest that you follow these steps once a month to ensure optimal performance.
These steps will work on the S50, S80 or S90i. If you are experiencing this issue on an S30 or any other device, please contact Navman Technical Support on 1300 628 626.
I used this personally on my S80 after it died during my work as a Security Patrol officer and I was not happy, its all fixed now and I have my Nokia N95 loaded with the same places just in case.
Feb 04, 2008 | GPS
that is probably due to the battery being totaly dead,
try using a mobile phone charger (nokia),
usb is for data transfers.
Jan 04, 2008 | Navman iCN 520 GPS Receiver
GPS Logo
74 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
