SOURCE: how is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
SOURCE: Truck won't start, new battery, lights keep flashing
Sometimes the new battery is not 100% charged. Put it on a charger or jump start the car, the alternator should then charge up the battery.
SOURCE: I have aa Arris modem connected to a lyksys
Try to power cycle your modem and the router for 2 minutes and If your Arris modem has a battery back up on it you must remove it in order to refresh the settings on it.
Keep in mind that after the cycle period you must turn On first the modem and make sure all lights of it are completely stable before powering up the router.
SOURCE: how to decode signal coming to the arris modem
I'm not exactly sure what you are asking but these arris modems have a built in website where you can check statistics, etc. What you would do is open up your web browser and punch in I believe 192.168.1.1 into your address bar.
SOURCE: Arris cable modem
if the power light is flashing then the modem is on battery backup and internet is disabled. plug the power cord into the modem or find a working power outlet, you should be set after that.
Power light flashing=bad
