Computers & Internet Logo
Shaun Welgemoed Posted on Oct 24, 2018
Need to link my device to my microsoft account
Sebymon Sebastian
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Nov 07, 2018
Sebymon Sebastian
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
2687
Points
41
Hi Shaun , Which device you use please ?
Regards,
Seb
I cant access my life emails on my laptop on the microsoft email that is needed
  • If you use any Microsoft services (Office, Outlook, etc.), you have a Microsoft account. If you don't have an account yet, you can create one during the sign-in process.
    • Go to Microsoft account and select Sign in.
    • Type the email, phone number, or Skype sign-in that you use for other services (Outlook, Office, etc.), then select Next. If you don't have a Microsoft account, you can select No account? Create one!.Note that we recommend using an email you already have and use regularly.
    • Type your password and select the Keep me signed in box if you want to go straight into your account next time (not recommended for shared computers).
    • Select Sign in.
Switch from a local account to a Microsoft account (Windows 10)
  • If you're using a Windows 10 device, you may have signed in without using your Microsoft account. When you follow the steps below, you'll be able to see which account you're currently using. To sync your settings and Microsoft Store purchases across all your devices, you'll need to sign in with your Microsoft account.
    • Select the Start button, then select Settings > Accounts > Your info (in some versions, it may be under Email & accounts instead).
    • Select Sign in with a Microsoft account instead. You'll see this link only if you're using a local account. Note that if you see Sign in with a local account instead, you're already using your Microsoft account.
    • Follow the prompts to switch to your Microsoft account.
2answers
I forgot my OneDrive password
As you are required to use Microsoft Account credentials to login to One Drive, you will need to reset your Microsoft Account password to get logged into OneDrive again. To reset your Microsoft Account password, use the link below:
https://account.live.com/resetpassword.aspx
GuruAid.com
1helpful
Verify security
Fix Mail Apps and Devices Show Incorrect Password Error After Enabling 2...
[Fix] Mail Apps and Devices Show Incorrect Password Error After Enabling 2-Step Verification in Microsoft or Gmail Account "2-step verification" is an important security feature which protects your online account whether its your email account or a social networking account. It asks for an extra security code each time you try to sign in to your account. This security code is sent to your registered mobile phone or alternative email ID.
Recently Microsoft enabled this 2-step verification feature for Microsoft accounts which are used for emails, Windows 8, XBox, etc. On the other hand Google is already providing two-step verification in its Gmail service since long time.
If you enabled 2-step verification feature in your Microsoft or Gmail account, you might be facing a weird issue. If you try to access your email account using an email client such as Windows Live Mail, Thunderbird, Microsoft Outlook, etc, it'll now allow you to sign in using your current password. It'll show you an incorrect password error message even if your password is absolutely correct. The same problem will also occur if you try to sign in using your Microsoft account in devices such as Xbox 360 or Android smartphones.
Now the question comes why does this problem occur? Why do these mail apps and devices not accept your correct password? The answer is very simple. These mail apps and devices were not designed to ask you for the extra security code which is required for 2-step verification. Since these apps and devices don't ask for security code, the 2-step verification procedure is not completed successfully, hence you can't sign in using your credentials in those apps and devices.
So what's the solution? The solution is very simple. Every company which provides 2-step verification feature, also allows you to create special passwords for these mail apps and devices. You can create separate passwords for each app and device and then you can use that special password to sign in to those apps or devices. Now those apps and devices will accept the new password and will allow you to access your account without any problem.
So if you have enabled 2-step verification feature in Microsoft or Gmail account and if you are facing login password problems in mail apps or devices, you just need to create above mentioned special passwords or codes to sign in without any problem.
Just follow these simple steps to create app passwords for your Microsoft or Gmail account:
A. Create App Password in Microsoft Account 1. Open your Microsoft account security settings page by clicking on following link:
Open Microsoft Account Security Settings Page
2. You'll see "App passwords" section at the bottom of the page which shows following information:
Some apps and devices don't support security codes. In these cases, you need to create an app password to sign in. 3. Click on "Create a new app password" link and it'll immediately provide you a new password generated randomly.
Now you can use this new password to sign in to a 3rd party mail app or device.
B. Create Application Specific Password in Gmail Account
1. Open your Google account settings page by clicking on following link:
Open Google Account Settings Pag
2. Now click on "Security" tab given in left-side pane. Scroll down on the page and you'll see "Connected applications and sites" section at the bottom of the page.
3. Click on "Manage access" button and it'll open a new page showing following information:Some applications that work outside a browser aren't yet compatible with 2-step verification and cannot ask for verification codes, for example: email programs including Outlook, Apple Mail, or Thunderbird, older Android smartphones. To use these applications, you need to generate an application-specific password. 4. Type any desired name in given text box and click on "Generate password" button.create_application_specific_password_google_account.pngThat's it. It'll immediately provide you a new password which can be used in any mail app or device to sign in.PS: If you want to remove or disallow any mail app or device to access your account, you can remove existing app password or revoke access from devices using the same account security settings pages as mentioned in above instructions.
how that helps good luck.
Jul 24, 2014 • hotmail.com
How i get my contact number back on my phone
Okay, you need to sync with Microsoft on a PC. You need to have a MS Account signed in on device Nokia Lumia 521. Then you need to link accounts under people.live.com and make sure accounts are linked like Google, Facebook, and LinkedIn or Twitter. Give it a shot and see how it goes.
How do i recover my password?
You will have to reset your password to your Microsoft account online.
To reset your Microsoft account password online, go to the Get back into your account page and follow these steps:
  1. In the first text box, enter your Microsoft account.
    Note If you don't know your Microsoft account, see Find your Microsoft account email address or password.
  2. In the second text box, type the characters displayed on the screen. This is to verify that you aren't a robot.
  3. Click Next.
On the next screen, you'll be given the option of having a reset link sent to you by email, or having a code sent to your phone.
Choose the option that works best for you:
  • Email me a reset link: Choose this option to have a reset link sent to the alternate email address that's associated with your account. When you open the password reset email, click the link to reset your password.
  • Send a code to my phone: Choose this option if you have associated a phone with your account where you can receive a security code by text or voicemail. If you choose this option, you'll be asked to re-enter the last 4 digits of your phone number as an additional security measure.
What to do if you can't use any of the password reset options
If you can't use any of the password reset options, you can still access your Microsoft account by completing an online account recovery form. To do this, go to Recover your Microsoft account and follow these steps:
  1. In the Email address text box, enter the email address for the Microsoft account you're trying to access.
  2. In the Contact email address text box, enter a current email address where we can contact you.
  3. In the third text box, type the characters displayed on the screen. This is to verify that you aren't a robot.
  4. Click Next.
To help maintain the security of your Microsoft account, you'll be prompted for several pieces of identification information that you provided when you initially set up your account.
Tips for completing the online account recovery form
  • Provide an alternate email address. Make sure you have access to this email address so that we can send your account information to you.
  • Answer as many questions as you can.
  • Use the information you provided when you created the account or last updated it.
  • Submit the form from a computer you frequently use.
  • Keep in mind that your email address may be country-specific. For example, if you created your account in Sweden, your domain would be "hotmail.co.se" instead of "hotmail.com."
After you complete the online account recovery form, you'll receive an email acknowledging that your request has been received, and you'll receive a response to that request within 24 hours (generally much sooner).
Notes
  • The password reset link will expire within 24 hours of delivery, so you'll want to keep an eye out for it. If you don't receive an email, check your spam or junk folder to see if any of the account recovery emails are there.
  • We highly recommend that you take a few minutes to update your account so that you can easily reset your password if you need to do so in the future. To update your security info, see "Update your Microsoft account security information " below.
Enter a new password
Once you've received an email with a password reset link, click the link in the email to reset your password.
After clicking the link, you'll be prompted to choose a new password and enter it twice. Passwords should be at least 8 characters long and should contain a mix of upper and lowercase letters, numbers, and symbols.
If you can't reset your password
If you've gone through the online password recovery process but haven't been able to provide enough information to complete the recovery, contact Xbox Support so that we can perform a deeper investigation into your account history and see if we can complete the verification process to provide you with a password reset. This process typically takes 24 hours, but it can be delayed if we are missing any information.
When you contact Xbox Support, have the following information available:
  1. The Microsoft account email address.
  2. An alternate email address where we can contact you if we have questions.
  3. The gamertag associated with the Xbox Live profile.
  4. The reference number from the email you received from Microsoft saying we were unable to verify your identification.
  5. The console ID or device ID of the console you use most often.
  • If you're an Xbox 360 user, provide your 12-digit Xbox 360 console ID. You don't have to be connected to the Internet or Xbox Live to collect your console ID. To find your ID:
    • Press the Guide button in the center of your controller.
    • Navigate to Settings.
    • Select Console settings.
    • Select System info.
  • If you're in the process of upgrading from Xbox 360 to Xbox One, provide your Xbox 360 console ID (see above for instructions). The more account history we can review, the better our chances of successfully recovering your account.
  • If you're an Xbox One user, provide the 16-character device ID. Your console must be connected to the Internet in order to access the Xbox Live device ID. To find your ID:
    • From the Home screen, press the Menu button on the Xbox One Wireless Controller.
    • Select Settings.
    • Select System.
    • Select Console info.
Password recovery
Unfortunately, if you cannot remember your profile password you are going to have to reset the password to your Microsoft account online.
  3. Click Next.
  2. In the Contact email address text box, enter acurrent email address where we can contact you.
  4. Click Next.
Notes
    • Select Settings.
    • Select System.
2answers
Forgot password code: 8015D002
Problem
You see the following error code and message when you try to sign in to Xbox Live:
Account does not exist.
Status Code: 8015D002
This may mean there's a problem with your account. For example, the security information for your account may need to be updated.
Solutions
Solution 1: Did you recently sign up for two-step verification?
If you recently turned on two-step verification, you may not know how to sign in to apps or devices that don't accept security codes. Some apps (like the mail apps on some smartphones) and devices (like the Xbox 360) can't prompt you to enter a security proof when you try to sign in. If you get an incorrect-password error with an app or device, you'll need to create a unique app password to sign in. After you sign in with your app password, you're all set to use that app or device. You'll use this new app password to sign in to your device instead of using your Microsoft account password.
You'll need to create and sign in with an app password once for each app or device that can't prompt you for a security proof.
  1. Sign in to your Microsoft account.
  2. Under Password and security info, tap or click Edit security info.
    If you're prompted for a security proof, enter it and tap or click Submit.
  3. Under App passwords, tap or click Create a new app password.
    A new app password is generated and appears on your screen.
  4. When you're prompted for your Microsoft account password on your Xbox console, enter the app password that you created online.After you sign in with your app password, you're all set to use that app or device. You will use this new app password to sign in to your device instead of your Microsoft account password.
Solution 2: Verify your Microsoft account security informationFollow these steps:
  1. Visit Microsoft account.
    Note If you forgot your password or can't sign in using your password, reset your password.
  2. Click Edit security info.
  3. Verify your security information. For example, verify the Phone number, Alternate email address, and Security question information.
  4. Sign out of your Microsoft account and then sign in again.
  5. Try to sign in to Xbox Live again.
2answers
Forgot my microsoft password
Forgot your Microsoft account password?
If you've forgotten your Microsoft account password or if you want to reset it, see Recover your Microsoft account password.
Also, refer to below link for more details on account details for Microsoft Xbox 360....
http://support.xbox.com/en-US/billing-and-subscriptions/account-management/forgot-microsoft-account
How do you download microsoft office?
Hi there! Welcome to FixYa!
If you need installation files for Office Suites I have all the link that you need. just let me know what version you are looking for.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
