Question about KLH Audio Players & Recorders
I have a klh r5000 audio video receiver and when I plugged it in it shows power but every time I press a function key it shuts off. What is the problem
    Master:
  • KLH Master
  • 830 Answers
Buy ????? ???? 19 ???? ? at https://ar.fifacoin.com, enjoy up to 10% off
Posted on Oct 24, 2018
SOURCE:
  • 319 Answers
SOURCE: TX-DS555 Audio Video Control Receiver
Get it serviced. It apparently has a circuit problem
Posted on May 08, 2008
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
Posted on Jan 24, 2009
mlapres
  • 757 Answers
SOURCE: No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
Posted on May 08, 2009
logosc75
  • 625 Answers
SOURCE: I just received a brand
Try plugging the charger into an outlet then, plug the charger into the remote, remove, plug in, remove...Do this for approximately six(6) times or, until "charge" appears on the remote. When "charge" appears on the remote leave it pug up to complete charge.
Posted on Jul 17, 2011
6ylucy
  • 742 Answers
SOURCE: I NEED AN OWNERS MANUAL FOR KLH R5100 AUDIO VIDEO
here is the user manual for KLH R5100
Posted on Jan 02, 2012
Power problem
If the protect function works but is causing you problems, cancelling the protection function should help, and it will be possible to enter the self-diagnostic function mode. This should disable all functions of the protection mode, excluding the 'excess electrical current detection' feature.
While pressing the "Tone Control" and "Info" keys, try pressing the power key to turn on the power. Keep pressing those 2 keys for 3 seconds longer.
this should activate the Self Diagnostic function, with your Protection Mode disabled.
in this mode the 'sleep' section on the tv's fluorescent display flashes to indicate that the mode is properly activated.
just be very aware, this function is normally there as a safety feature and i cant guarantee that disabling it altogether won't cause other problems down the road. best of luck!
Jun 06, 2014 | Yamaha Audio Players & Recorders
My klh audio receiver modle r5100 it turns off when i turned it on how do i fix it
If it powers on for about 3-5 seconds then shuts off it likely has shorted output transistors. Contact a service center as that is not an easy repair.
Apr 19, 2014 | Audio Players & Recorders
STATUS OF MY ORDER?KLH R5100 AUDIO VIDEO RECEIVER?
Sorry. I haven't the user manual for KLH 5100 audio video receiver with me now.
Nov 01, 2011 | KLH R5100 Receiver
I DON'T KNOW ALL FEATURES AND CONNECTIONS FOR MY KLH R5100 AUDIO VIDEO RECEIVER.I NEED A MANUAL FOR MY RECEIVER.
I don't have the manual with me. I found KLH R 5100 with user manual in the following link. Tray to contact them.
OK
http://www.ebay.com/itm/KLH-R-5100-Receiver-Hi-Power-/250902259353
My KLH R5100 display comes and goes, most of the time is just dead, any suggestion ?
From your description you have bad connections on the display board, or intermittent power feed from the main board, it will take somebody that is handy with a soldering iron or a professional to check it out.
Dec 29, 2010 | KLH R5100 Receiver
Connect R5100 to DVR/Monitor
use component audio to the HDTV and optical audio to your KLH reciever. The component and optical are always active at the same time. I work for TWC if you have more questions.
Apr 15, 2008 | KLH R5100 Receiver
Klh r7000 no sound
go to this site dexsoft.com/blog. Is under : KLH R7000 no audio repair. Problem solve
Oct 14, 2007 | KLH R3100 Receiver
Power supply board
That also can be a PROTECT mode. Maybe you should check connections.
Oct 11, 2007 | KLH R3100 Receiver
KLH R3100
Try pushing the speaker button under the power button on the front.
Aug 02, 2007 | KLH R3100 Receiver
55 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Daniel Dollive
Daniel Dollive
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
