SOURCE: inactive features
Is the phone system working but the voicemail did not come back up ? Can you tell me what kind of voicemail you have, ist should be marked on the voicemail system ?
SOURCE: Also trying to initialize voicemail, says Feature 983 inactive
Feature 983 gives cess to System Administration; This Feature will ask for a Log:
Feature 981 Opens A Mailbox your mailbox # should consist of three digits. First what is the name of your mailbox system?
SOURCE: Norstar Flash problem
Cycle the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair.
Good Luck!
Dear Annabelle,
Is the machine call pilot 100 or 150.if 100 the 2 leds in your left hand side should be on also in your right hand side the middle led should be on same for 150 the 4 leds in your left hand side should be on.1) Try to unplug the power cable and re-connect it again.2) Make sure that the the output telephone cable [100 (2 pair) or 150 (4 pair)] depends on the device comming from the call pilot to the Nortel PABX connected properly from both sides. dont hesitate to contact me if you are facing any doubt.Goodluck and Kind Regards;
Ahmed Safaa El-DeebTelecom & Network Engineer
