SOURCE: Need assistence in setting the date and day on my citizen 8700 eco drive
There is an ID number I need to help you further it is the Movement Caliber number probably on the back. Once I have that I can help you further.
Regards,
Worldvet
SOURCE: date setting in a citizen eco-drive calibre 8700 watch
http://www.youtube.com/watch?v=RF3hC1hgZz4
hope this link illustrates u better
All the best,
Prince
SOURCE: setting a Citizen Chronograph watch
assuming the battery isn't dead (IF IT IS DON'T TAKE THE BACK OFF, YOU
WILL LOSE THE SPRING THAT MAKES THE ALARM SOUND) the button on the
bottom right click it until the function selector is pointed to time,
then pull the button out, then the top two buttons i believe change the
hour hands. before setting the time you will need to zero this watch
out, or calibrate it or the date will not change in synch with the time
at midnight.
my battery is dead and i am a truck driver and am therefore having a
difficult time (no pun intended) finding a place i can get parked to
have my battery changed. please believe me when i tell you that you
will lose this spring, a jeweler lost mine once and it took months to
order a new one
SOURCE: I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
SOURCE: how to set the day on Citizen eco-drive
http://www.citizenwatch.com/COA/English/settings.asp
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
