I would to fix the wire to their correct place. thanks.
SOURCE: Need wiring diagram '70 Chevy 2T trck w/electronic ignition conv
Make sure you give it a good tune up. Make sure that your rotor is moving when you crank it over. If it is moving then you will need to replace the distributor module.
SOURCE: need a wiring diagram for electronic ignition system for a 1972 plymouth duster 318 cu
A place on the web for such info is at For A Bodies Only. Here is a link.
Electrical and Ignition
