I cannot select a hdmi input or any other input.
SOURCE: Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
SOURCE: What is the code for a Sanyo DP26640 26" LCD TV
Hello 1. Turn on a device (e.g., VCR or DVD Player) and, if applicable, insert media, (e.g., video cassette or disc). NOTE: Please read steps 2 to 6 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2. 2. On the remote control, press a device key once (i.e., AUX or TV). NOTE: Use the AUX key to program control of an Audio Amplifier or Receiver, a DVD Player, a Home- Theater-In-A-Box Device, a PVR (or DVR), or a VCR. 3. Press and hold Setup until the selected mode key blinks twice, then release Setup. 4. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first. 5. Enter the first four-digit code for your device. If you perform this procedure correctly, the selected mode key will blink twice. NOTE: If you enter an invalid code, the selected mode key will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code. 6. Aim the remote control at your device and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 6, trying each code listed for your works. If it still does not work, try Searching For Your Code. NOTE: If the device does not have a
Remote code for Sanyo TV with Comcast Custom DVR-3 device universal remote control is
0154
brand until you find one that
Power key, press the (Play) key
SOURCE: whee is the analog audio output for sanyo dp26640
After reviewing the manual ( http://www.manualslib.com/manual/306783/Sanyo-Dp26640.html#manual - page 6), it does not appear that this television has an analog output. A fix to this problem would be to purchase a digital to analog audio converter (just Google this) and some inexpensive solutions are available.
Good luck,
