Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Dark spots on tv
I've noticed more and more dark spots on my tv screen. How do I get rid of these?
  • cybergiant Mar 22, 2008
    dark spots
    200 to clean the last time
    what to do to prevent
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Posted on Dec 04, 2007
  • KING REX
    KING REX Jun 11, 2014
    My tv only develops a black big triangle on the screen 15 inches by 6 inches only when i connect the DVD/BLU-RAY Player. It does it at every begining of the scene. When i press the input button, it diasspears. However, when it appears as my 2 yr old girls is watching the Princesses movies, she cries until when i fix it. Am tired of this. The Rideau sears who sold me the LG 46 Inch TV closed shop. What can i do?
    Champion:
  • 317 Answers
Call tech ...suggest to clean optics.
Posted on Nov 26, 2007
If you do what CrzyFt85 says with 2 peoples you wont beleive the change on your tv...very inportant to clean that mirror if you want the benifit of your DLP TV otherwise youll have a dark picture if dust on your mirror........tyvm for your info CrzyFt85 very helpfull for me i had those black spot on my screen too and now gone and beautyfull colors also.
Posted on Mar 18, 2008
    New Friend:
Michael Street 1 solutions Feb 27, 2013 There are two round caps on each side of the housing behind the screen held in by a single phillIps head screw. Remove one of them to expose the interior which houses the projection bulb and the mirror. Take a large microfiber cloth and attach it to an extendable duster handle, and wipe of the bulb. That should eliminate the spot. To bring back your original picture, wipe the projection mirror on the back of the housing off, also using the microfiber cloth. The whole process will take no more than 10 - 15 minutes. Enjoy your brilliant picture, again.
Posted on Feb 27, 2013
SOURCE:
Have an LG LCD 42" flat screen probably 3-4 years
no there is no way, you have heated up the screen backing. only way is to remove the lcd screen and change it. as the screen its self is only 0.01 or 0.02mm at the most thick, you will probably smash the screen.
Oct 01, 2013 | Televison & Video
Bright Spot
A fixed blue area on screen may be a display panel (main screen unit)
Here is a link for the boards etc this set uses--take your pick:
http://www.shopjimmy.com/sceptre-x460bv-f120
May 17, 2012 | Sceptre 46 X460BVF120 LCD TV
Blue spot on my hitachi 50"rear projection tv model 2006 50vs69a
Do you have a center speaker near it? maybe move it, that is what I have done and it seems to have gotten better.
Jun 09, 2009 | Hitachi 50VS69 50" Projection HDTV
White Spots Streaks on DLP Screen
If you bought the set new you might just want to contact the manufacturer - if they are decent, they might just try to help you out with your dilemma.
Apr 02, 2017 | Mitsubishi WD-65833 65" HDTV
Dark stain on display screen
it should be a stain spot on the camera lens..try taking it to an authorised service point and have it cleaned
Dec 06, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Dark spots on my JVC 61" tv
dark spot could be a faulty led. if you put a program on that is in white screen you should see all the leds light up the screen. dark spot will be were the led is not working. if on white screen and they all lite up but still dark around the area, it could be the lcd screen. and could be dying pixels. and try this video https://youtu.be/wlA2rcrAOCs
Feb 10, 2018 | Toshiba 55H70 55" Rear Projection...
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
Samsung LCD Question
The model is a LN-S4041D. A 40 inch LCD. I can send you a photo but I can't get the file size small enough to post
Feb 09, 2008 | Televison & Video
Dark spot in centre of screen.
I have a little dark spot that i noticed it today too on my canon SD870IS i hope somebody can tell us what's the problem
Jan 02, 2008 | Olympus Stylus 700 / 700 Digital Camera
Dark spot on the top of the screen
May you should have a replacement for that, seems is has a factory damage on it!
Apr 05, 2007 | Philips 51PW9303 51" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
2,576 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
