Radio Communications Logo
l
laurie Posted on Oct 22, 2018
WHAT TYPE OF OIL IS USED 2017 PETERBUILT TK - Radio Communications
What does connect service tool mean on a peterbuilt?
The message to connect service tool is to let you know that a dealers or repair facilities scan tool/computer needs to be plugged in/connected to your vehicle to read out what fault codes are set.
Mar. 28, 2017
My check engine light came on and received a "connect ...
https://www.justanswer.com > Car Questions > Truck Repair
1helpful
VW Edition 30 Caddy (2012) Van 97000km had scheduled oil change on 21/07/2017 with only short city drives until 9th August when Turbo disintegrated 40km into a freeway drive at 100kmph. What cause?
If you used a different grade of oil or graphite oil, the nozzle that sprays oil on the bearings in the turbo can plug up stopping lubrication and that will cause a massive failure
Where is the fuel pump located on 2000 peterbuilt 379
most diesels have the fuel pump integral with the pressure pump
you are talking about the transfer pump and not the high pressure injector pump a mention of what engine you have is better than the truck make as peterbuilt normally run 3 makes of engines ---cat, detroit or cummins
2helpful
Why is the facebook website blocked on my pc?
Most probably the access to facebook is blocked from your windows or network firewall.
The administrator of the PC or network has to remove the RULE from firewall(s) that deny access to facebook site.
If above is not possible (e.g. in case it was made on purpose by the administrator, e.t.c.):
Alternative you can try to connect to facebook through proxies that can bypass your firewall.
Below you can see some of these proxies. Just go there, type www.facebook.com in the URL box and press go. Whala!!!
http://www.facesaver.net
http://facoxy.com
http://vroxy.com
http://subick.com
http://midhat.com
http://vroxy.tk
http://vcloak.tk
http://ninjaoxy.tk
http://cloakme.tk
http://ktunnel1.tk
http://ktunnel2.tk
http://ktunnel3.tk
http://ktunnel4.tk
http://cloakninja.tk
http://proxyninja.tk
http://ninja-cloak.tk
http://ninjaproxy1.tk
http://www.airproxy.tk
http://ninjaproxyarea.tk
http://www.fastninjaproxy.tk
http://www.freeninjaproxy.tk
http://www.bypass-facebook.tk
http://www.getonfacebookatschool.tk
When ever i tey to coonect ww.facebook.com it gives me error that u unable to cnnetc www.facebook.com..how ever i can open all other sies other then facebook... sooo plzzzzz help me out i also canged...
You or the administrator of the PC or network has to remove the RULE from firewall(s) that deny access to facebook site.
Below you can see some of these proxies. Just go there, type www.facebook.com in the URL and press go. Whala!!!
http://facoxy.com
http://vroxy.com
http://subick.com
http://midhat.com
http://vroxy.tk
http://vcloak.tk
http://ninjaoxy.tk
http://cloakme.tk
http://ktunnel1.tk
http://ktunnel2.tk
http://ktunnel3.tk
http://ktunnel4.tk
1helpful
Compatability
The Kenwood TK-3200LU15 is the 2Watt replacment model for the TK-3101. the TK-3202 or TK-3203 are 4 watt models that can be used. Although, they have to be programmed with the frequencies and codes you are using. The TK3101 came with defualt GMRS/FRS frequencies.
HiTechWireless.com
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
