SOURCE: Ice Maker
Charles, these models have a habit of the inlet tube freezing over. Make sure the black tube feeding the trough is clear. You may want to disconnect it from the back and see if you can blow through it. I use hot water in a baster to clear them all the time. Another thing is to check the optics. When opening the freezer door the red optic light on the right should flash 2x with a pause repeatedly. When you close the left hand emitter flapper the light should stay on. If it does this your optics are good. Because of these optics the new ice-maker has to be jumped started into a cycle. Once started you can monitor the fill. Catriver..post back.
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
SOURCE: Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
SOURCE: Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
SOURCE: blue ice from ice maker
I have this problem too. Seems to be a couple of blue paper washers in the unit that the water filters through and they break up. Ive had this issue go on for more than a year now with Liebherr trying over and over not to claim responsibility. Ive sent them the blue washers and photos and all to get analyzed and they simply do not call me back. Their service center didnt even know there were 2 blue washers in the unit. Seems to be a mess. In any case I still have a very large amount of blue paper dust in my ice and its unuseable. Any solutions?
The water supply line from the water inlet valve enters the rear of the freezer and releases the water into a large diameter fill tube. The fill tubes hangs above the fill cup which funnels the water into the ice mold. If the fill tube and fill cup are improperly aligned, water may spill out instead of going into the mold.
