Question about Dacor Ovens
I came down this morning to find my dacor oven panel off.
If voltage to unit check transformer
3 Suggested Answers
SOURCE:
TheMobilian
  • 8220 Answers
SOURCE: f-1 problem on dacor, MCD230s oven is
THAT F 1 INDICATES A FAULTY SIGNAL FROM THE TOUCJHPAD TO THE CONTROL ERC. .HERE IS THE PDF DACOR OVEN MANUAL WITH ELECTRONIX DIAGNOSTICS I NEED A BEER
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 21, 2009
Krazytech
  • 725 Answers
SOURCE: Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Posted on Sep 19, 2009
I have a blodgett zephaire gl oven. unit kept buring up 24v transformer, was old bad centrifical switch in motor. I replaced motor with brand new one, unit still buring up 24v transformer.....why ?
A short somewhere causing it to overamp. Put a 3amp inline fuse on the secondary side (24v side) on the hot wire. This will save the transformer and blow the fuse not the transformer. The centrifugal switch prolly wasn't bad. So I would trace the wire coming off transformer and look for bare wire or loose wires. Anything that would cause a short
May 04, 2016 | Blodgett Ovens
Dacor wall oven MORD230 cont'd beeping,disconnecting power to unit did't work,error code 01 appear on display
Hello. The error means there is a shorted key on the keypad. The part number you will need is 701044-02, called "membrane panel assembly, black". The main board, if needed, is 101991, called LED display module. Hope I helped you!
Aug 21, 2015 | Dacor Ovens
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
Brown wire only 10 amps
One of your high voltage transformers is not functioning. You could have a bad capacitor, diode, magnetron or transformer.
Mar 25, 2013 | TurboChef TORNADO Electric Oven
I have a LG LRE30453SW Electric Range and the relay pcb keeps going bad. I get an F7 error when starting the oven. The first time I noticed the black line in, from the power terminal, to the relay pcb was...
First, check the 220v line and breakers are properly grounded and that you are getting a constant 220v at the plug. Then you will need to check the transformer on the unit.To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
If all that looks good, then you will need to replace the control board. Here is a link to the parts for your range.
Regards,Richard
Dec 08, 2011 | Ovens
I have power to the range but the oven was not working
High voltage circuit .......be careful Don't. work until you know how to use multimeter Never try to check the secondary volage across the transformer.its very risky Just check the primary voltage at the transformer if you know how to do it otherwise just leave it If you know how to use multimeter then let me know Thanks Please rate me
Aug 28, 2011 | Smeg Ovens
Microwave ewave ew13f1st gets veryhot and smells like something eletric is burned. what could be the problem?
A heavy burning smell ,and a usually a big humming sound ,plus possible smoke,is the High voltage transformer has burnt up. Usually replacing the transformer is a much as replacing the microwave.
Gene
Aug 05, 2011 | Ovens
Electrolux EOB5630X. Oven works fine for about 20-30mins then cuts out (light in oven turns off and grill will not work at this time either). Will work fine again after temp in oven cools but cuts out...
the electronics are heating up and cutting out.that cold be a bad clock assy. or there's a fan in there that could be bad or i've seen on some models there's a screen in where the fan is,it gets clogged with dust and the air can't blow to cool down the electronics.if it is the fan and you keep using it like that it will take out the computer board or clock assy. same part.
Nov 13, 2017 | Electrolux EOB5630 Ultrafan Electric...
Ovens Logo
64 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
