Question about Casio Office Equipment & Supplies
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
SOURCE:
SOURCE: casio DR-T220
Turns out the incorrect type of paper was being used. The paper needed is the paper that is sensitive to pressure and this paper was not.
Posted on Jul 22, 2008
maridian
SOURCE: Loading Paper into a Casio Calculator
This isn't too complicated. And for the lazy guy that just put a phone number for the fix, what the heck do we need FixYa for anyway? :\ For cryin' out loud! :) )
1. Slide the clear plastic cover toward the back to remove and flip of the metal spool holder up. Place the roll of paper on the holder. (Make sure the paper drops off the "back" of the spool for proper feed.)
2. Feed the paper into the bottom slot at the **** end of the calculator.
3. Feed the paper through that bottom slot along the inside case under the black guide inside. If you tilt the calculator correctly, you can look inside and see there is a way to slide the paper under the guide.
4. Making sure the paper slides as far as it can, press the FEED button until the paper starts feeding.
5. Feed enough paper to slide through the clear plastic cover and you're all set.
This isn't factory, it's just what I figured out playing with the thing. If you can think of a better way of explaining the procedure, by all means edit this and post!
God bless!!
Maridian
Posted on Nov 14, 2008
SOURCE: How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Posted on Jan 23, 2009
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
SOURCE: loading paper tape
Well, I just had a long and vigerous fight withmy new HR-8TM. I came here and read all the before mentioned solutions. Then the idear struck me. Instead of cutting the paper even all the way across the roll, I cut it slanted on the sides and straight across the middle " __ " and guess what it passed the roller feed through.
It worked for me, maybe it will work for you.
Posted on Feb 14, 2010
Do you have plastic arm to hold paper for casio HR100TM
No, we actually have not one part for any product at all.
We are an information service only.
Please type your needs into the search engine of your computer and see if there is a dealer who can help you.
God bless your efforts.
Jun 22, 2018 | Casio Office Equipment & Supplies
How do I change the print head on HR 100TM casio calculator
You grasp it and then pull as hard as needed to remove it. next, shove the replacement into the space the removal revealed. Easy. huh?
Mar 18, 2016 | Casio HR100TM 2-Color Printing Calculator
The paper feeder does not work. It hums and shows error.
DEBBIE LOOK IN THE OPERATORS MANUEL OR CALL CASIO CUSTOMER SUPPORT
Jan 21, 2016 | Casio Office Equipment & Supplies
How do I get a casio hr100tm to print the total?
Once you enter your number like so (5.00 press (+) 11.00 (+) 5.00 (-) then press the *key, should be bottom key next to + = key). Hope this helps, sorry to be so late with an answer.............
Jul 22, 2014 | Casio HR 100TM Portable Printing...
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
How to load paper in casio calculator HR-100TM
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
Sep 05, 2011 | Casio HR-100TEPlus Calculator
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Feb 05, 2010 | Casio HR-8TMPlus Calculator
HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Jul 18, 2009 | Casio FR-2650A Calculator
I'm so stupid
  1. Remove the top gray lid of the calculator
  2. Insert paper through the back side slot near the power charger
  3. Turn the calculator on print
  4. Press FEED a couple times
Feb 26, 2007 | Casio HR-100TEPlus Calculator
358 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
