SOURCE: onkyo ts595 goes into protect mode with volume increase
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
SOURCE: my onkyo tx ds747 is saying protect even if i dont
Hello
maybe you have defective power transistor output and this is shorted, or the problem is in the power section like shorted diode shorted capacitors or open circuit may cause this, and the STK IC if shorted you got protect warning..
Angel
Thansk...
SOURCE: tx-ds747 no display light,when powering on only
Sounds like the "Pure Audio" mode is turned on. This mode is designed to use the amps power to dedicate to audio processing and sound quality. It turns off all front panel lights and video processing. Check you remote or thr front panel of the Onkyo for a "Pure Audio" button.
SOURCE: ONKYO TX-DS747 SWITCHES FROM A TO B SPEAKERS HOW
The problem could only be in the a/b switch, you may need to install a new switch.
SOURCE: If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
