I have a daewoo he front loading washing machine with a top loading automatic soap dispenser, where you add in a lot of soap and it automatically measures and dispenses it into the laundry. It is full and not dispensing soap, so I think it must be clogged. How do I fix it?
SOURCE: LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
SOURCE: Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
SOURCE: he2 front loading washing machine leak at the soap dispenser regi
Hi dlypooh, thought I would post the solution here as well for anybody who needs to do a search in the future...
Remove the dispenser, pour water into the opening and make sure water
can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly (re: dlypooh), open the washer door and
feel around the bellow for anything blocking the water inlet port into
the washer (socks can sometimes get wedged up there and cause a
blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
SOURCE: washer is leaking water when it starts from the soap dispenser
the fill tube is located at the top tub cover and more than likey the tube is defective or the discharge anti spash guard is cracked. nbcrca:)
SOURCE: water leaking from soap dispenser
water leaking from soap dispenser. so water pours out under the soap dispenser
