SOURCE: circuit breaker trips on electric hot water heater circuit
Check the voltage at the water heater. Sounds like the element is burnt out and is tripping the breaker.
If it is more then 5 years old I would check.install a new heating element.
SOURCE: hot water does not come out
I pulled the water heater out of the rv and found the one way value broken and cloged.replaced with new one $9.12 and put back together.works great.
SOURCE: Intermitent heat from Atwood 10 gal marine water heater
Water level safety shutting down heat source
SOURCE: I have a 6 gallon
Your on right track. When this happens and small flame still there, pull wire(s) off at gas valve, or test for voltage from ECO to gas valve. No voltage, then there should be no gas. Change gas valve.
Testimonial: "Changed the gas valve, now heater works as it should, No fumes and no flame after shutoff."
