SOURCE: Samsung HT-DB120 no voices on dvd
when unplug it from the main outlet, sometimes it goes to defualt setting. check your audio setting..make sure you set according to the speakers that you have. good luck
SOURCE: ps3 sound setting for Acoustic Solutions tv
i had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
SOURCE: i can't hear the voices when i play dvds
Change your audio setup to stereo. if you are running two speakers
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
SOURCE: I have a Phillips DFR-1600 DVD/Surround Sound
where can I find a remote for my DFR-1600 DVD/surround sound
