There is not a fuse for protection from this insitent. However the damage on your machine is deoent from how long you left it on with 220v. It can be damage full but it can also not hapent anything. Have you check it again with 120V, since there is a chance that it can still work normal but in any case if not working you may need only a small repair by an eperience percon.
SOURCE: Nespresso pixie c60 only brews for a few seconds on full cup mode
Does your machine need decalcifying? Kits are available from your capsule supplier. If you've already done this, try holding both buttons down - usually for 5 seconds or till the buttons stop flashing - while you turn the machine on. This should reset the machine to its original factory settings. Good luck.
