A detailed description of this procedure is found in the manual of your watch. You can find the right manual with the module nr. on the back of your watch (4 digit number in a rectangle)
The manual for your watch can be downloaded via the link provided below:
Timepieces Watches
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
SOURCE: Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: how to set analog time on casio fishing gear watch
Follow this link and get manual:
Rate me, please.
SOURCE: i purchased wr50m watched i donot lnow how to set time both digit
Check out my tips and tricks here in FixYa and you will get manual for your watch.
SOURCE: Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
