Ron Hathaway Posted on Oct 20, 2018
How do i set the time on my memorex mc6306bka?
How do I set the time
To set the time on a Memorex Mi4604PBLK Clock Radio, hold down the 'set time' button first and then the 'source' button, at the same time. But you must push the buttons in that order, 'set time' and then 'source'. The time display on the front will flash between dim and bright. Use the volume dial to change the time. Time is set, and the flashing display will stop after a few seconds.
2helpful
Memorex Model Mi3021BLK clock setting
Here is a link to the instructions for the Mi3020; instructions should be similar:
http://www.memorex.com/PageFiles/981/Mi2001_ENG_SPA%5B1%5D.pdf
Go to page 11 for setting the time.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
1helpful
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
5helpful
2answers
I don't know how to set the clock for a MA4203 model
I couldn't find the information for your particular model, but I did figure out the general procedure for Memorex alarm clocks currently in production:
  1. Make sure power is turned off (no radio or whatever playing). Press the Time Set button (on some models, this is the Skip Search Back button for an iPod docked in the unit).
  2. When the display blinks (on one model, the volume control knob lights up), press the Hour button (Vol. -) to set the hour, then press the Minutes button (Vol. +) to set the minutes. On the model with the light-up volume control, rotate the volume control knob to set the time.
  3. When you have the time set, either wait 15 seconds or press the Time Set button again to start the clock.
Setting the alarm works the same way on single alarm models, but the Alarm Set button may be the Skip Search Forward button. Dual alarm models have separate Alarm A and Alarm B buttons.
1helpful
Need instructions emailed for Memorex MB 2058
here is a pdf of the manual:
http://www.memorex.com/support/support_product_detail.php?pid=50434
Can't get time and day display off screen
With the MT1192 Memorex set, it's the RECALL button on the remote that toggles it on and off the screen.
Top Memorex Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
NOEL
NOEL
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
