SOURCE: Phone wont detect bluetooth H700
Mine could be discovered when powered off/ on my cellphone and retried... Sounds like solution to M$ programs, eh? :)
SOURCE: dont know how to work my blue tooth to my phone
You have to get the phone to recognise the bluetooth headset first. The manual should tell you how to do this. Normally you have to go into the bluetooth menu on the phone and get the phone to detect the headset, and then type in the pin code, normally 0000.
SOURCE: my dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
SOURCE: blue tooth icon missing from system tray now Dell
You need to connect a wired usb mouse first and try pairing the bluetooth mouse again with your system by going to the control panel and opening your bluetooth device manager. Click add a device and press the connect button underneath your mouse. System should be able to detect your mouse. If that failed, try replacing the batteries with fresh ones.
