A locksmith might be able to open it for a fee.
Some safes allow a battery to be connected by an external cable, but I don't know on your model.
An article suggest contacting the manufacturer using the phone number on their web site.
https://www.hunker.com/13419279/how-do-i-open-my-bunker-hill-safe-when-the-key-is-lost
Harbor Freight Tools
TECHNICAL PROBLEMS
1-888-866-5797
Monday thru Friday
7am to 4pm (Pacific Time - USA)
https://www.harborfreight.com/household.html?CatPath=All%2BProducts%252F%252F%252F%252FEverything%2BElse%2F%2F%2F%2FSafes&RequestData=CA_CategoryExpand
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
SOURCE: Cannot get my Bunker Hill Safe open.
get the key number that is listed above the key hole and then call 888-299-3427 for a replacement
SOURCE: Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
SOURCE: have a bunker hill safe. battery died. lost
Remove the sticker on the front panel with the SKU number, behind it will be a small hole, use a small screwdriver to remove the screw, then carefully remove the number pad. You will see the place to use your key.
SOURCE: bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
