SOURCE: change the time setting from 24 hour to 12 hour AM PM
Check this
Go to start>settings
Go to the system tab and the regional settings icon
Go to the time tab and it should be hh:mm:ss tt for 24 hour clock
Let me know how that works out for you
SOURCE: 24 hour time setting to 12 hour
You can't! Trust me I have been dealing with watches for 2 years now and currently work in the industry as a watchmaker's assistant.
There are different settings for each different brand, Casio have there own configure and so does Seiko etc.
Best way I know is to push buttons to something happens. Please note DO NOT DEPRESSED ALL PUSHERS AT ONCE, this 99.99% of the time will reset the entire device!.
Usually there is a 'reset' pusher which will once depressed (either immediately or after a few seconds of pushing it) will flash, then you work out which one is the 'next' button until you get to the 12/24hr then press the Up or down pusher (usually but NOT always opposite side to the 2 previously menitioned pushers).
As for auto's or quartz that's another matter.
Hope this helps?
SOURCE: How do I set a seth thomas weather station from a
Press and hold the mode button until the year starts flashing in the upper left. Tap the mode button 3 times. You will see "24hr" with the 24 flashing. Press the + or - button on the back. Press the mode button 4 more times (or just leave it alone for about 30 seconds and it will go back to the normal display).
SOURCE: AWRC-1P How do I the clock from 24 hour to 12 hour
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and you're done .
