A good idea would be to unplug it and then plug it back in to ensure it is secure. Another thing you can try is to plug the cord into another outlet. After you’ve checked the power outlet in the wall, ensure the cord securely connects to the back of the TV
Its likely the power supply. They are notorious for problems. The backlight is powered in quadrants. Your lower left quadrant is failing. I love fixing things but Vizio is nothing but trouble. I wont even work on them they are so poor to repair.
If you are handy, check the power supply for the backlight for bad solder. If it looks ok, then Id use it until it goes bad again.
ShopJimmy
$77.42 - Out of stock
This Vizio 0500-0612-0030 Power Supply / LED Board for M550NV (0500-0612-0030) works for these ... The odds we'll get it soon: Bad (What does this mean?).
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair ... I can not get it to power on so I ...
? 6:13
DiY How to Fix led / lcd Vizio TV service repair - no powerservice repair review guide no red blinking led ... Theorange/amber light turns on when plugged in. But the TV won'tturn on after that (the light does not turn white).
? 4:01
https://www.youtube.com/watch?v=MDzCzZdgbdg
Jan 5, 2012 - Uploaded by Leo P
This is model XVT3D424SV, I was watching a DVD, I switched the input to TV, tried to connect to netflix, it was ...
InstructablesSo my Vizio TV was flashing on & off rapidly every time I switched it on. ... good way to get something to work, but it got things working until I had time to repair it.
Aug 26, 2015 - Vizio TV power cord plugging into a power outlet. Do you know ... Powerproblems might require service or replacing parts inside the TV. Before ...
? 6:21
https://www.youtube.com/watch?v=B_ae3f7C3jQ
Feb 20, 2012 - Uploaded by Brady Smith
Learn how to replace your LCD Visio TV motherboard and hear a few facts ... ANYBODY KNOW HOW TO FIX OR WHAT NEEDS TO BE FIXED IF THE ... I have found that I need to replace themainboard in my vizio 42 inch. .... hey, man. can you help me out? i got a VIZIO E3D320VX from ebay brand new.
? 2:48
https://www.youtube.com/watch?v=a_8URZW356E
Dec 6, 2012 - Uploaded by ShopJimmy.com
Top Common Vizio LCD TV problems for bad Main Unit Boards:... To be best prepared to replace the Main Board inside of yourTV, you will need the following ... If you have any further questions regarding your repair, simply post a ... i can see on one of the small black squares (sorry i dont know what they ...
remove back, only exposed board there is PS, look where blue/brown AC wire plugs into it, fuse (F1) is there (5amp-250v) if fuse is good and you get no power or front light replace that board, or start component level troubleshooting (usually regulator trans or SM fuses (000)
