SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
SOURCE: Print Cartridges Refer to documentation (No function works)
I was getting this same VERY unhelpful error and the only thing that solved it for me was to buy another genuine HP black cartridge (350XL). As soon as I put it in, it cleared the error and sprang to life. As a matter of interest, before this happened, the HP Toolbox utility was also saying that the old cartridge was nearly empty. So why on earth doesn't the printer tell you the same thing??? Come on HP - get your firmware sorted. Disappointed.
SOURCE: Left hand light flashing orange and printer wont
Check the following:
Make sure you have removed the seal on each cartridge.
Turn of Printer, open all shutters, front and back and close them firmly, firmly.
Make sure there is no paper jam.
Usually these are the immediate causes of this kind of scenario.
Then try to print again.
SOURCE: I have installed 2 new ink cartridges. The orange
Are the cartridges genuine new hp, or are they compatibles, or refills? If not genuine hp, get some and see if that solves your problem.
