SOURCE: I have a ARCHOS 28
We had a similar problem yesterday. It happens as soon as we plug in to USB cable to PC. We found that after we left it for some time it did eventualy kick back in to life. We could use it until we plugged in to USB again. Trying to find a solution to the problem right now. You can press and keep hold of volume up button while you turn back on and that kicks in the diagnostic software menu. From there you can find the "Force screen calibration" which we did but it doesnt sort out the problem of plugging in USB
SOURCE: My Archos 101 tablet's full sized USB port doesn't
This seems to be a widespread problem with the Archos 101 tablet. There have been 2 firmware updates since the problem was first reported, and neither seems to have fixed the issue for anybody, which strongly suggests that it is a hardware issue, in which case you'll need to do an RMA. I recommend contacting the retailer you purchased through so you can get a replacement unit or a refund.
SOURCE: Archos 101 internet tablet cant get
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
SOURCE: Brand new Archos 101 8
Looks like you're sending back another one!
Don't muck with it, you could void the warranty!
SOURCE: My archos 101 tablet is frozen and none of the
If you have access to battery, remove battery and put back in.
