If the motor nameplate says reversible and has no wiring diagram, open the connection cover to look for it there. Something like swap t5 and t8 or brown and yellow, along with its connection to power instructions or diagram.
How do you reverse a single phase 5 HP motor check it on YouTube will give you the answer
SOURCE: converting 3 phase compressor to single phase
Start w/ a single phase motor. Or maybe your question is just confuseing me.
SOURCE: have a 3 phase 7.5 HP IR compressor,want to put a
You will use two of the original three wires. Not knowing if you have a motor starter and how it is wired makes it impossible to give you details.
BE AWARE that a 7.5 HP single phase motor is going to draw a massive starting surge compared to a three phase motor. I assume this is on a 240 volt system as it would NOT be practical to use a motor that size on a 120 volt system.
Expect to require around a 30 to 50 amp single phase feed to the motor.
SOURCE: 230v single phase motor has W1 W2 and U1 on
THIS IS A CLASSIC , THE GREEN ONE GOES TO GROUND THE OTHER 2 DON'T MATER LONG AS YOU DO NOT PUT THEM ON TOP OF EACH OTHER. THIS IS NOT LIKE YOUR CAR WITCH IS DC..THIS IS AC ALTERNATING CURRANT ..ALTERNATING ! .. YOUR POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
SOURCE: I would like to connect a pressure switch to the motor starter
hi! there, single phase compressor motor need a starting capacitor base on the rated capacity in horse power,you can check this on the tag of the compressor motor how many horsepower was indicated,it should be for single phase motor starting capacitor has a capacity of micro farads.for a 1 horsepower = 15 to 18 micro farads stating capacitor if you have more than 1 horsepower you can basically proportion the value of capacitor you need or ask the dealer how much capacitor you need on your motor the connection of pressure switch with a four terminal should be connected both on common line L1 and running capacitor line L2 .if you open the cover of pressure switch there are 4 terminals,2 terminals are connected when normally close or no pressure they connected on series connection on the common line one terminal connected to common line of the compressor and the other terminal on L1 to the pushbutton switch to L1 supply line.the 2 other terminals also connected in series withe line capacitors L2 to yhr power supply line.hope this will help you a lot.just rate my fix thanks a lot.
SOURCE: Can I change model 754 machine from three phase to
You need a phase converter. We just did that. 3 phase to 1 phase.
