Computers & Internet Logo
v
vianey torres Posted on Oct 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All the leds on exept wifi on my NBG-416N I plug mi router and all the leds come on exept the wifi led what can be the problem
Vladimir Frolov
Level 3:
  • The Master 2,075 Answers
  • Posted on Oct 18, 2018
Vladimir Frolov
The Master
Level 3:
Answers
2075
Questions
Helped
415549
Points
6445
Connect to router via cable. Sign into admin panel of router and then check if WiFi is enabled. If not, just enable it.
2 Related Answers
amips
  • 66 Answers
  • Posted on Aug 26, 2011
SOURCE: My computer recognizes the wireless network that I
Is it enabled on your laptop? It can be turned off! All laptops are different, some have a switch or on/off button for the wireless receiver, some use a keystroke/combination. Look for picture of radio signal on your F-keys, if you find it, hold down the FN key and tap the radio key, it will toggle it on then off.
Anonymous
  • 531 Answers
  • Posted on Sep 14, 2011
SOURCE: how do I reset NBG-416N
Hi dtloya
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System and my answer seems to be of some relevance to you, please consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question. Please include information about your Operating System. Doing so helps us makes faster, more accurate and more assured Remote Diagnostics leading to better quality and more useful Advice, Answers, Guidelines , How-Tos and Solutions.
If you look at the back of the Router, you should find a Reset Button or a small Recess that can be pushed in with the tip of a pen. Press and hold this button or the Press Plate in the Recess for a 5 seconds, then release it to Reset the Router to Factory Settings and the factory-set Username and Password (often both are factory-set to USERNAME = admin and PASSWORD = PASSWORD or PASSWORD1 or something similar).
On some routers, holding the Reset Button/Press Plate for a longer period (15-20 seconds), can allow the User to change the Router's Username and Password.
Windows XP
Start > Run >ipconfig.exe > Enter, will reveal the IP Address of the router.
Windows Vista:
Start > type "command" in search box at bottom of Start Menu > click "Command Prompt" at top of Start Menu > type "ipconfig" after the C: \>
Windows 7:
Start > type "cmd" in the search box at bottom of Start Menu > click "cmd" at top of Start Menu > type "ipconfig" after the C:\>
Log onto the internet and type in the IP Address in your browser window and press enter. Access the Router Settings > Security and follow the steps to configure it and enter a new password.
Ensure that your internet connection is encrypted with a private network key and protected by a new password, so that neighbours cannot pirate your internet connection and thus use up your bandwidth and slow down or degrade your signal.
To avoid a future reoccurrence of the same problem, save the new password in a discreet way in My Folders on your cellphone.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
I need help putting a password on my wireless connection through my router. How do I do this?
1. Connect your internet to a computer
2. Go to internet browser -> type in http://192.168.1.1 in the address bar
3. You should see the router login page. Type in default user name and password
username : admin
password: 1234
4. Follow a setup wizard to put your device name and wifi password.
I have attached the manual link below:
ftp://ftp2.zyxel.com/NBG-416N/quick_start_guide/NBG-416N_1.pdf
hope this help.
2answers
Disable ap/client isolation to allow chromecast to work
You need to login to the routers web interface and the settings will be in the advance WiFi section, probably a tick box.
A typical web interface can be found at the following address in your browser http://192.168.1.1/
Username usually admin and password could be password or blank or 1234 or admin. Check with manual.
1helpful
Router doesn't respond
May be time to "send it out into the world". It may be deceased, no more, ceased to be, what you may have is a dead router. See this, it will explain: http://www.youtube.com/watch?v=4vuW6tQ0218
How to get zyxel nbg 416n routher to connect the netgear Prosafe 16-port 10/100 desktop switch for inhome ethernet net woke.
Plug a straight through Ethernet cable from a LAN port on the router to any port on the switch. That's all it takes. Granted most network equipment today has logic to switch the pin outs so any Ethernet cable should work.
How to set up zyxel NBG416N in universal repeater mode
Yes Zyxel nbg-416n does indeed support repeater mode but you need to make sure you have at least firmware version v1.00(USA.5)C0 and you can switch to that mode via maintenance/sys op mode.
I need step by step instructions on how to set up my router
Can't get any easier than following the user guide.ftp://ftp2.zyxel.com/NBG-416N/user_guide/NBG-416N_1_Ed1.pdf
Assuming your modem is on an plugged in.
  1. Plug an ethernet cable from the modem to the router's WAN / Uplink port
  2. Plug the power cable into the router
  3. Plug another ethernet cable from one of the LAN ports (1-4) to an ethernet port on the computer your going to use to setup the router.
  4. Open a web browser and enter 192.168.1.1 and press enter
  5. When prompted for a login use USER: admin PASS: 1234, press enter
  6. Now follow from page 35 of the guide listed above.
At the least change the SSID (the name of your network broadcasted)The password to login to the routerEnabled WPA2 PSK for your wireless security this will keep 99% of people off your network
Comment if you have further questions
My computer recognizes the wireless network that I have set up with my NBG-416N Router, and my internet works when I plug into the ethernet. However, I can not get any internet from my wireless.
It will connect but Cannot set up and change password and username with default or any others found on google
Here is a link to the user guide for your modelftp://ftp2.zyxel.com/NBG-416N/user_guide/NBG-416N_1_Ed1.pdf
Located on the first page is the defaultsAddress: 192.168.1.1user: adminpassword: 1234
If this still is not working I would recommend locating the reset button and holding it in for 15 seconds this will erase any previous config and restore the default above.
Comment back if you need further assistance
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
