Question about Karcher Garden
Greetings I have a Karcher Hot Pressure Waster HDS 80 S and was Informed that this MACHINE of mine is over 37 years old. I would be Great full if I could be provided with Electrical Drawings
Karcher Hot Pressure Washer 80 S Electrical Drawings Is All Written In Germany... Zeichnungs-Nr 0.086-773
SOURCE:
SOURCE: karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work
- Faulty fuel solenoid valve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger)
- Dirty fuel filter,
Take a look at those simple things and let me know if its any of these.
I have a Karcher HDS 750 1989 Year model
This machine just keeps going, it's had a fairly tough life but it has stood up to it all,
i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump,
other than that thats all it's needed, it's still going strong to date
Very robust machine.
my e-mail is cgodfx@internode.on.net
Cheers Matt.
Posted on Nov 07, 2008
SOURCE: KARCHER HDS 1000 de
hi jim i have the same unit diesel burner and diesel engine have you tryed a new accelorater cable?
Posted on Jan 08, 2009
  • 32 Answers
SOURCE: hi,karcher hds hot pressure washer now pressure
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Posted on Jul 04, 2009
  • 88 Answers
SOURCE: I am looking for a workshop manual for karcher hds
hi could you post your email address and i can email you a full pdf file, also on the chassis of the machine there will be a silver sticker could do with all the numbers to find which modle it is regards
Posted on Jan 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: Now door close pressure tab is broken unable to get washer on
Check you yellow pages for an independent repairman. You'll find all the prices nearly equal for competitive purposes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
The amber RM10 and RM11 light is flashing on my karcher 7/10
Regarding this model, I am not that informed. But similar machines, it is an indication of water softener warning lights. If it is a fuel problem and machine is full of fuel, then the fuel level sender, is faulty.
Regards,
MG.
Feb 12, 2015 | Karcher Garden
I would like a karcher instruction manual for a HDS650 pressure washer
I believe the HDS sends spark to the ignitor any time the machine is on ( hot or cold) You should hear the crackle of the ignitor in the burner area. Perhaps the ignitor rods are not properly aligned. Perhaps your ignitor coil is bad. There are several safety switches and the thermostat that would keep the burner from firing if they are bad. There is a pressure switch that turns on and off the motor for hot or cold operation. That is apparently working. I think there is a flow switch that turns off the burner. The thermostat might not be opening and closing contacts and that will keep the burner from working. I believe there is a high temperature safety switch as well.
Jul 15, 2014 | Garden
Service center philippines
you may be able to retro fit from a wasjing machine
Mar 14, 2014 | Karcher Garden
Karcher professional hds 655 steam cleaner not much water pressure
If there is nothing wrong with the machine but you have lost power over the years you have been working it. It could be that the machine needs a new pump kit or/and change the pressure nozzle.
smaller issues could be that the pump isnt turned to high pressure or if you have an servo control on the gun that it is turned to low pressure instead of high pressure.
May 14, 2012 | Karcher Garden
I am looking for a workshop manual for karcher hds 555 ci hot pressure washer.or access to where i can download one. any assistance is greatly appreciated
Jan 19, 2010 | Karcher PSI Electric Pressure Washer
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
Mar 21, 2009 | Karcher Garden
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Cheers Matt.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
37 people viewed this question
Top Karcher Garden Experts
John Trevino
JOHN LAPIER
Joseph Mueller
Joseph Mueller
Are you a Karcher Garden Expert? Answer questions, earn points and help others
