Makita Hm1307cb Demolition Hammer, 1 1/8 In Hex, 35 Lb 14f120 Logo
N
Nia Tool Posted on Oct 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Makita 35lb breaker wont hammer. Power light turns on but wont hammer.
We have replaced the cord previously and it's getting power but no response from the motor
Parson's Repair Shop
Level 2:
Sergeant:
  • Makita Expert 284 Answers
  • Posted on Mar 03, 2021
Makita Expert
Level 2:
Sergeant:
Answers
284
Questions
0
Helped
226473
Points
685
Most likely it is the brushes - most of their models in that series have auto-stop brushes that push away from the armature when they reach a certain wear point.
5 Related Answers
Anonymous
  • 126 Answers
  • Posted on Jan 27, 2008
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Anonymous
  • 360 Answers
  • Posted on Feb 13, 2009
SOURCE: Makita 2704 I overloaded my motor
if the motor RPM drops dramatically when the noise starts, it is probably a dry motor bushing, if this just started, lubricating the motor may just fix it.
Anonymous
  • 1185 Answers
  • Posted on Aug 27, 2009
SOURCE: power cord worn out where it enters motor, have to
You have popped the fuse in the plug top or have burnt out the wires in the cable
No matter you have got to shorten and re-wire the cable into the cleaner or get a new lenght of flex and do the same thing.
Some are easy to re-wire some are a pain
Anonymous
  • Posted on Oct 11, 2009
SOURCE: Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Anonymous
  • 2176 Answers
  • Posted on Mar 16, 2010
SOURCE: How do I replace the power cord for a makita palm
without knowing what the model number is you also have to remove the pad assembly and usually you will find some there if all removed you can GENTLY pry the cover halves apart. Go to Makitatools.com with you model number and you can download a breakdown for this tool.
Testimonial: "Thanks for this info. The Makita tool site is helpful as is your information. I found the schematics for my model BO4510. Wish me luck. JK"
Replace power cable 8406c
just grab a short extension cord and open up the drill and cut the female end off the extension cord and either solder it in or crimp it in if that seems doable. If it runs in reverse switch the wires.
Makita battery wont keep charge
Given the problems with Makita Li-ion batteries there are 2 likely reasons, you have a faulty charger or both batteries are faulty, the best option is to find another charger to try your batteries on and see if they charge, depending on the age of the drill you may be able to get the batteries or charger replaced by Makita, a lot of them have been replaced out of the warranty period because they are known to fail prematurely, take the faulty item back to the place of purchase with you invoice and put the pressure on for replacement
I have a makita hm 1810 hammer green light stays on hit switch light goes off
As stated in the manual:
The green power-ON indicator lamp lights up when the tool is plugged to the mains. If the indicator lamp is lit but the tool does not start even if the tool is switched ON, the carbon brushes may be worn out, or the motor or the switch may be defective. If the indicator lamp does not light up, the mains cord or the indicator lamp may be defective.
Makita wire come out
Hi dean
Do you mean a Mkaita 1304b? Is it just the main cable that has come out? in which case you can undo half of the handle and reconnect it to the switch.
Hi there i have a makita HR2470 and last week i was chasing out a wall and it just stopped mid chase,i checked the transformer it was connected too that was fine,then i've checked the lead at both ends all...
Try to make a direct JUMPER.Take an old electrical cord cable and plug it in the electric socket and the other end of the cord with 2 cables already peel off and jump the + and - to the + / - of the hammer and see if power on if so the on/off switch is bad and need to replace.If the problem
persist probably the motor is burn.
If you need more help come back.Post / thumbs / testimonial are welcome!
1helpful
2answers
My makita hmo860c breaker drill has stopped working power light is on ?
I purchase a rotory hammer on ebay and it was listed as a makita, i was trying to get a spare part for it from makita. I gave them the information that is printed on a lable on the side of the drill, 66015c, 850W 110V,26mm and to my suprise they told me that it was not one of their drills, I have a few of these drills still being sold on ebay as makita. is there anyway that anyone can help me with this query.
2helpful
DISHWASHER WONT POWER UP
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 13, 2009 • Dishwashers
Which features are more user Friendly?
accessible power controls, in-line body which provide nice balance in various working positions, power dial which is easy to read and reach and also large and accessible enough to use with gloves on or of.
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
2answers
Burners wont come on.
Hi , try to check the power outlet , posible recock the breaker , check also the piower cord test with continuity tester both end of cord (diconnect before you test ) switch on knob if tester response , try to connect to power outlet test the electric stove.
Top Makita Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Makita Hammering Expert? Answer questions, earn points and help others
