SOURCE: I need the wiring diagram
Hi gilmore_lisa
Here is the Installation guide for your oven. The wiring diagram for connection plus step by step instructions start on page 39.
BE CAREFUL. MAINS ELECTRICITY CAN KILL
If you are unsure about anything... get an electrician to do this work for you. Thanks for using FixYa
regards
tobotek
SOURCE: Oven will not lite
Older is BETTER !! Replace the igniter,even if it is glowing
REPLACE it !
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
SOURCE: Oven wont lite ?
How them oven Ignitors work
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
