Water accumulates, then eventually gets frozen. this is an LG French Door Refrigerator. recently underwent a comprssor replacement.
SOURCE: Ice in Refrigerator Section
there are 2 possibilities. first the drain is blocked causing water to overflow from the defrost water gulley at the bottom rear of the inside of the fridge. this can form ice as it is close to the division between fridge and freezer. second, the .fault of ice growth can be caused by breakdown of the cabinet insulation. of the two, the first is the moree likely. to test drain is cloear, pour a little water down the drain. if it does'nt flow freely, push something flexible down the drain hole till blockage is clear
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
SOURCE: the refrigerators accumulate ice
the fridge distrubutes cold by air movement. A overstuffed fridge can have trouble. There is a fan that blows a controlled amount of freezer air over to the food side, altho when this goes you usually have frozen freezer and food too warm. Make sure the air is allowed to move.
SOURCE: water accumulation under vegetable drawer model
its the problem of the compressor present in your fridge... if its malfunctioning, then water wil accumulate under the vegetable tray
SOURCE: Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
