Doesn't display wash temp. but shows temp rising for rinse cycle then shuts off entire unit at 199 degrees celsius then display goes to flashing wrench and P1. How to fix?
SOURCE: what is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
SOURCE: "HO" flashes on display during washing.
The HO actually means the system is in a water heat delay. It means the water wasn't hot enough and the dishwasher is heating it up. Mine does it during the Hi-Temp wash.
SOURCE: Wash Temp will not get above 140
It depends on the design & the programming. By chance if the thermostat is faulty this can happen. However refer user manual and consult the service provider or the manufacturer!
