Question about Franke Coffee Makers & Espresso Machines
I have a Franke flair coffee machine and need to replace the damaged drip tray, where can I purchase a drip tray?
SOURCE:
  • 40 Answers
SOURCE: Hi, we have aa Saecco
Possible areas are the steam valve leaking or the boiler valve housing is leaking. I suggest Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
  • 4 Answers
SOURCE: Franke coffee system, always same error message ''fill water tank''
What you would have to do is take the side panel off to get at the solenoid. It is probably sticking closed and not letting the water fill into the boiler.
Posted on Mar 21, 2009
z34aga
  • 137 Answers
SOURCE: Water in the drip tray of coffee machine
take out the mecanism and clean it how is instructed in manual, than get it back carefuly. Pay attention on position of mecanizm.
Posted on Mar 28, 2009
  • 29 Answers
SOURCE: our franke flair coffee machine keeps saying
this is usually due to the overtemp device activated on one of the thermoblocks, an engineer will be required to replace this item,
Posted on Nov 19, 2010
  • 910 Answers
SOURCE: We have noticed that the
Looking at the PDF Cleaning Instructions at the following link you'll see O-Rings on the Frothing Head, Items 1 & 2 in the Centre Picture. There are also O-Rings on the white Coffee Outlet Pipes in the Right Picture.
http://www.caffesociety.co.uk/uploads/pdfs/franke/flair-cleaning.pdf
I suspect the one you've found is from the Coffee Outlet Pipes and may be worth just replacing them both with new (link below) while you've got it stripped apart.
http://www.xpresscoffeeuk.co.uk/product.php/1756/franke-spares---o-ring-silicon-3-4-x-1-9-70sh-re--1p315145-/4cbc2fb43a7b40012dfabba2eb047d55
If you just wet the O-Rings a bit they should just slip back over the collar at the front of the pipe.
Posted on Jul 10, 2011
No milk and steam dispensing from Franke Flair coffee machine
I am a Franke technician. After and possibly during the descale, because probably you haven'nt done it in a long time, steam was able to escape through the fittings as the limescale damaged the silicone rings beforehand. The steam damaged the klixxons or the thermoblock itself. You will need one of us unfortunately....
Feb 17, 2018 | Franke Coffee Makers & Espresso Machines
My franke flaire machine keeps displaying empty drip tray its empty and clean and will not let me do any thing else can you help
AT THE BACK OF THE DRIP TRAY YOU HAVE CONTACTERS LIKE SWICH SOW ITS BEST TO REMOVE THE TRIP TRAY AND TELL THE HAIR DRYER DO THE JOB TRY AGAIN
Mar 03, 2016 | Franke Coffee Makers & Espresso Machines
Franke flair trips the electric when turned on
It might be good idea to disconnect the coffee valve and switch on machine as it's 230v and might be shorted and tripping and blows fuses.If it is then replace brew valve.
Apr 13, 2014 | Franke Saphira Espresso & Coffee Maker
Can't get rid of drip tray missing
the basic solution is to clean the contacts at the back of the drip tray, they can easily become soiled. assuming you have done this the contact points in the coffee machine may also need cleaning. this can be done by gently rubbing fine sand paper on the contact where the drip tray contact are inserted. if problem still persists then the internal contacts may need replacing.
Mar 15, 2014 | Franke Coffee Makers & Espresso Machines
My frankie flair grinds the beans but the water just goes straight to the drip tray why
this problem is usual caused by the valve at the base of the brew unit. not working correctly or the solenoid which controls it. usually a replacement brew unit can resolve this.
Dec 17, 2013 | Franke Saphira Espresso & Coffee Maker
Franke flair
Where can I buy new seals or a whole new drop tray please
May 15, 2013 | Franke Flair Espresso Machine with...
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
Hi, Franke Saphira. 'Empty Drip Tray' message doesn't shift when in descale mode - not in any other mode though, only when trying to descale. Any ideas? Cheers
If you keep the empty drip tray message, especially after making a drink or cleaning operation this points to a leak internally on to the drip tray contacts. or from the thermoblock leaking onto the wiring loom behind the front door panel. An engineer will be required to fix this as the correct seals will be needed. I have been a Franke Service Engineer for 15 Years.
Sep 29, 2010 | Franke Saphira Espresso & Coffee Maker
Hi Hope you can help me. I have a Franke Flair coffee machine which a relative as just given me from there pub. I switch it on and it seems ok until i place the drip tray in position as soon as the...
240vac is then switched when the drip tray conntact connect. 240vac goes to both thermoblock heaters and pump.possibly a dead short inn the heating or pump circuit.check all connections and look for slack connections around the pumps. brewing motor runs and magnetic drian valve opens also at switch on, check also.
Apr 10, 2010 | Franke Saphira Espresso & Coffee Maker
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
Coffee Makers & Espresso Machines Logo
50 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
jonathan Hanson
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
