Televison & Video Logo
Posted on Oct 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I have an old Dell plasma tv and it was pushed over and I have no picture. I was getting a picture after it was tilted over but it wouldn't come right on I would have to wait a few minutes before I would get a picture and now I don't get a picture at all. Can you possible tell me what may be out on it l.
Jeffrey Groves
Level 3:
  • Master 573 Answers
  • Posted on Aug 26, 2019
Jeffrey Groves
Master
Level 3:
Answers
573
Questions
Helped
140425
Points
1832
There could be any number of things wrong with it based on the information that you provided.
A qualified technician can take a look at it and give you an idea of what might be wrong with it.
5 Related Answers
Anonymous
  • 36 Answers
  • Posted on Feb 04, 2009
SOURCE: HP Plasma TV - Lost Picture
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
Anonymous
  • 55 Answers
  • Posted on May 09, 2009
SOURCE: PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
Anonymous
  • 39 Answers
  • Posted on May 18, 2009
SOURCE: Picture problem with Maxent Plasma MX-42HPM20
Very common problem on these sets caused by bad surface mount caps. Check on ebay for a repair kit it's the only place I know where one exists.
Anonymous
  • 563 Answers
  • Posted on Jul 11, 2009
SOURCE: JVC 42'' plasma TV (PD-42WX84) screen turns grenn after 10 minutes
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Anonymous
  • 92 Answers
  • Posted on Sep 06, 2009
SOURCE: 50 inch Sanyo Vizon Plasma TV. Has sound but no
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Testimonial: "Thank you for your response. We were driving ourselves nuts - fuzes checked out fine and not other guess where to turn. We appreciate your help!"
Picture is fine for about an hour then goes fuzzy
Hello Townsend, It sounds like a problem called blooming, or you are having a problem with focus control which are signs of a problem in the horizontal and high voltage section of the tv in the case of plasma TV this would be the excitation circuit. I would suggest that you take the set to a TV repair shop to effect repairs.
3helpful
Dell 4201C Plasma 42" -
Hi, Mary.
This sounds to me like it is a bulb issue, and not something worse, like failed capacitors.
If that is the case, then yes, it is worth repairing it.
You need to get the old bulb out, either by removing it yourself, or by having someone take it out for you, and the take the old bulb to Fry's or BestBuy.
They both keep tv projection bulbs for flat screen tv's in stock.
I hope that I've helped you understand what is going on, and that it helped.
Have a nice day, and good luck.
Hello, My tv is about 5yrs old.We heard a loud
You need to replace Y main board & buffer, which will cost you around $600-700. Since the TV is five years it will be better to go with new, and it won't be worth enough to spend $700 for old TV.
Hope this helps.
Shane
I just replaced the ysus board. I have sound but no picture. at least with the old board i had an extremly dark picture. I'm not sure what to do now.
Hello.
Put your old board back - if TV will turn on and dark picture will still present - then you just have purchased defective board. If even old board won't bring picture back - probably Plasma Panel couldn't take it anymore and died.
regards.
Russ.
2helpful
5 year old plasma that looses half the picture
Hello. I recommend that you forget the repair for two reasons. 1. Pricey. 2. You still have a 5 year old set with no warranty. In the last five years, the tv technology has come so far. The HD is fabulous. The new sets cost less to operate and they are so much better than they were five years ago. Joe
42" Dell plasma TV
Y SUS and Buffers are usual culprit.
You can get it from guy at
[email protected]
He has everything for Dell TVs
3answers
42 in dell plasma, no picture, sound works fine
if i tell you how i fixed it can i charge you?
My Plasma TV
how long have you had the tv ?
2answers
1/2 the picture
Hello
You will have to a tec. for this one as you have lost half of your vertical sweep.
Sorry
guy9
Top Dell Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Paul Bade
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
